Arne_stl Skrevet 18. juli 2007 Skrevet 18. juli 2007 Hei. Jeg spiller Lotro så det tyter ut av øyrene mine,Her ein dag spilte jeg så kome jeg til å tenke på at det ble nevnt i en patch at det sko komme et program som gjorde at spillere kunne spille inn musikk(med/til instrumetet) å så bare lage ein hurtigtast eller no så ble den spillt av in game. Noen som husker det ? Tror det kom med den patchen som inholdt den nye landsdelen. Forresten er det noen som vet om når neste del av landet kommer ? Klarer nesten ikkje ta tankene mine vekk fra spillet, er så enormt !! hehe
Campin Carl Skrevet 25. juli 2007 Skrevet 25. juli 2007 Det er mulig med G15 tastaturet uten noen form for patch eller mod, men jeg har ikke hørt noe om det idet hele tatt
Topguy Skrevet 25. juli 2007 Skrevet 25. juli 2007 Utrolig hva Google greier å grave opp... Okay, here is the basic steps to use the new music system and play prewritten songs. Step 1: First go to ...\My Documents\The Lord of the Rings Online\Music and make sure that the Music folder exists. If the music folder is not there, don't panic. Just create a new folder and name it Music. This will be the folder that you put all the prewritten music. Step 2: All the files that are readable by lotro are written in ABC format. If you don't know what that is, google it or check out the official ABC website here: http://www.walshaw.plus.com/abc/. To create a ABC file either open up a text document or download a ABC editing program such as Mid2Abc at http://claremusic.tripod.com/music.htm. Step 3: Either write the ABC language or just paste in the musical piece you collected into the text file (or whatever you are using). Then save it as songname.abc (or whatever you want to name your song, just keep it short as you will have to write this out every time you want to play the song and make sure you save it as .abc) in the ...\My Documents\The Lord of the Rings Online\Music. Step 4: Finally, when you are in game, start playing music just like you would any other time with the /music. Then just type /play songname.abc (or whatever you named your song). Then your character will began playing the tune you prepared in advance. A good resource to check out is the official lotro forum http://forums.lotro.com/showthread.php?t=40311 where they have started a nice collection of ABC format tunes.
