Unormal treghet i X, feilkonfigurert?
Hepp.
Jeg bruker et nVidia GeForce FC5200 (pci) i min stasjonærboks, med twinview. Etter siste reboot merker jeg at alt går forferdelig treigt. Xorg bruker rundt 90% av CPU når jeg spiller av film, og rundt 20% ellers. Før brukte jeg nvidia-driveren i apt (husker ikke versjonsnummeret), men nå har jeg lagt inn den nyeste for å prøve, uten noen bedring. Kan legge til at jeg har brukt dette kortet lenge, uten problemer (selv om jeg ikke husker hvilke nvidia-drivere jeg har brukt).
Kan det være at jeg mangler noe i configen? Evt noe for mye?
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath	"/usr/share/fonts/X11/misc"
FontPath	"/usr/share/fonts/X11/cyrillic"
FontPath	"/usr/share/fonts/X11/100dpi/:unscaled"
FontPath	"/usr/share/fonts/X11/75dpi/:unscaled"
FontPath	"/usr/share/fonts/X11/Type1"
FontPath	"/usr/share/fonts/X11/100dpi"
FontPath	"/usr/share/fonts/X11/75dpi"
# path to defoma fonts
FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load	"bitmap"
Load	"ddc"
#Load	"dri"
Load	"extmod"
Load	"freetype"
Load	"glx"
Load	"int10"
Load	"vbe"
EndSection
Section "InputDevice"
Identifier	"Generic Keyboard"
Driver  "kbd"
Option  "CoreKeyboard"
Option  "XkbRules"	"xorg"
Option  "XkbModel"	"pc105"
Option  "XkbLayout"	"no"
Option  "XkbOptions"	"lv3:ralt_switch"
EndSection
Identifier	"Configured Mouse"
Driver  "mouse"
Option  "CorePointer"
Option  "Device"  "/dev/input/mice"
Option  "Protocol"  "ImPS/2"
Option  "ZAxisMapping"  "4 5"
Option  "Emulate3Buttons"	"true"
EndSection
Section "Device"
Identifier	"NVidia GeForce FX5200"
Driver  "nvidia"
BusID  "PCI:02:09:0"
Option  "NoLogo" "1"
Option  "RenderAccel" "true"
Option  "ConnectedMonitor" "crt, crt"
       Option  "NvAGP" "1"
Option  "TwinView" "1"
Option  "Metamodes" "1280x1024,1280x1024"
Option  "SecondMonitorHorizSync" "28-64"
Option  "SecondMonitorVertRefresh" "43-60"
EndSection
Section "Monitor"
Identifier	"Samsung Syncmaster 710v"
Option  "DPMS"
HorizSync	28-64
VertRefresh	43-60
EndSection
Section "Screen"
Identifier	"Default Screen"
Device  "NVidia GeForce FX5200"
Monitor  "Samsung Syncmaster 710v"
DefaultDepth	24
SubSection "Display"
 Depth  1
 Modes  "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
 Depth  4
EndSubSection
 Depth  8
EndSubSection
 Depth  15
EndSubSection
 Depth  16
EndSubSection
 Viewport 0 0
 Depth  24
EndSubSection
EndSection
Section "ServerLayout"
Identifier	"Default Layout"
Screen 0	"Default Screen" 0 0
InputDevice	"Generic Keyboard"
InputDevice	"Configured Mouse"
InputDevice     "stylus"	"SendCoreEvents"
InputDevice     "cursor"	"SendCoreEvents"
InputDevice     "eraser"	"SendCoreEvents"
Option  "Xinerama" "Off"
EndSection
Section "DRI"
Mode	0666
EndSection
