MS32DLL.dll.vbs? virus eller?
Hei!
Jeg har fått et lite problem med å gå inn på harddiskene mine..
når jeg dobbelklikker på en av diskene så kommer det bare en feilmelding fra Windows Script Host der det står: Finner ikke skriptfilen D:\MS32DLL.dll.vbs.
Dette kommer uansett hvilken stasjon jeg skal gå inn på. Finner ikkje så veldig masse om denne filen så jeg lurer på ka d kan vær.
Jeg prøvde å innstallere windows på nytt men den beskjeden kommer uansett..:(
Noen som har noen som helst info om dette?
Første side på google.
Discovered: November 23, 2006
Updated: February 13, 2007 1:02:30 PM
Type: Worm
Systems Affected: Windows 2000, Windows 95, Windows 98, Windows Me, Windows NT, Windows Server 2003, Windows XP
When VBS.Zodgila is executed, it performs the following actions:
  1. Creates the following files:
          * %Windir%\MS32DLL.dll.vbs
          * [DRIVE LETTER]:\MS32DLL.dll.vbs
          * [DRIVE LETTER]:\autorun.inf
            Note: %Windir% is a variable that refers to the Windows installation folder. By default, this is C:\Windows (Windows 95/98/Me/XP) or C:\Winnt (Windows NT/2000).
  2. Adds the value:
      "MS32DLL" = "%Windir%\MS32DLL.dll.vbs"
      to the registry subkey:
      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
      so that it runs every time Windows starts.
  3. Adds the value:
      "Window Title" = "Hacked by[REMOVED]"
      HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
      to modify settings in Internet Explorer.
  4. Attempts to copy itself to removable drives and create registry entries every 200 seconds.
Recommendations
Symantec Security Response encourages all users and administrators to adhere to the following basic security "best practices":
    * Turn off and remove unneeded services. By default, many operating systems install auxiliary services that are not critical, such as an FTP server, telnet, and a Web server. These services are avenues of attack. If they are removed, blended threats have less avenues of attack and you have fewer services to maintain through patch updates.
    * If a blended threat exploits one or more network services, disable, or block access to, those services until a patch is applied.
    * Always keep your patch levels up-to-date, especially on computers that host public services and are accessible through the firewall, such as HTTP, FTP, mail, and DNS services (for example, all Windows-based computers should have the current Service Pack installed.). Additionally, please apply any security updates that are mentioned in this writeup, in trusted Security Bulletins, or on vendor Web sites.
    * Enforce a password policy. Complex passwords make it difficult to crack password files on compromised computers. This helps to prevent or limit damage when a computer is compromised.
    * Configure your email server to block or remove email that contains file attachments that are commonly used to spread viruses, such as .vbs, .bat, .exe, .pif and .scr files.
    * Isolate infected computers quickly to prevent further compromising your organization. Perform a forensic analysis and restore the computers using trusted media.
    * Train employees not to open attachments unless they are expecting them. Also, do not execute software that is downloaded from the Internet unless it has been scanned for viruses. Simply visiting a compromised Web site can cause infection if certain browser vulnerabilities are not patched.
Endret av Zyrex_
Takk for svar.
Fann nokke av det samme,men fann ikke nokke om hvordan jeg fjernet det.. Finnes det en god gratis webbasert virusfjerner som kan ta det?
