problemer i PREY
Hei, skulle starte PREY, men fikk denne feilmeldingen etter å ha installert:
Prey 1.2.116 win-x86 Sep 18 2006 16:54:05
2297 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT & x64
2048 MB System Memory
512 MB Video Memory
Winsock Initialized
Found interface: {821D7027-22C5-4B81-A5D2-E1E141DF5F49} Realtek RTL8139 Family PCI Fast Ethernet-kort - Miniport for pakkeplanlegger - 0.0.0.0 NULL netmask - skipped
Found interface: {534F5EC7-6C3B-47EA-8D88-D8F6742806AB} D-Link Air DWL-510 Wireless PCI Adapter - Miniport for pakkeplanlegger - 192.168.1.107/255.255.255.0
Found interface: {EBD86140-F278-4229-99D4-04F633A07A4C} VIA-kompatibelt Fast Ethernet-kort - Miniport for pakkeplanlegger - 192.168.1.109/255.255.255.0
Sys_InitNetworking: adding loopback interface
prey using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 D:\Spill\PREY\base\game00.pk4 with checksum 0xe0be2928
Loaded pk4 D:\Spill\PREY\base\pak000.pk4 with checksum 0x7dc00ede
Loaded pk4 D:\Spill\PREY\base\pak001.pk4 with checksum 0xd06647b1
Loaded pk4 D:\Spill\PREY\base\pak002.pk4 with checksum 0x57dce443
Loaded pk4 D:\Spill\PREY\base\pak003.pk4 with checksum 0x263006fe
Loaded pk4 D:\Spill\PREY\base\pak004.pk4 with checksum 0xcc075380
Current search path:
D:\Spill\PREY/base
D:\Spill\PREY\base\pak004.pk4 (3739 files)
D:\Spill\PREY\base\pak003.pk4 (4111 files)
D:\Spill\PREY\base\pak002.pk4 (5337 files)
D:\Spill\PREY\base\pak001.pk4 (6270 files)
D:\Spill\PREY\base\pak000.pk4 (3318 files)
D:\Spill\PREY\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
2647 strings read from strings/english001.lang
Couldn't open journal files
couldn't exec editor.cfg
execing default.cfg
couldn't exec preyconfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 10 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
...initializing OpenAL
...calling LoadLibrary( 'openal32.dll' ): failed
sound: STEREO
...using GL_ARB_multitexture
...using GL_ARB_texture_env_combine
...using GL_ARB_texture_cube_map
...using GL_ARB_texture_env_dot3
...using GL_ARB_texture_env_add
...using GL_ARB_texture_non_power_of_two
...using GL_ARB_texture_compression
...using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_filter_anisotropic
  maxTextureAnisotropy: 16.000000
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
...using GL_EXT_texture3D
...using GL_EXT_stencil_wrap
...using GL_NV_register_combiners
...using GL_EXT_stencil_two_side
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
...using GL_ARB_vertex_buffer_object
...using GL_ARB_vertex_program
...using GL_ARB_fragment_program
...using EXT_depth_bounds_test
---------- R_NV20_Init ----------
----------- R200_Init -----------
Not available.
---------- R_ARB2_Init ----------
Available.
----- R_ReloadARBPrograms -----
glprogs/test.vfp
glprogs/test.vfp
glprogs/interaction.vfp
glprogs/bumpyEnvironment.vfp
glprogs/ambientLight.vfp
glprogs/shadow.vp
glprogs/R200_interaction.vp
glprogs/nv20_bumpAndLight.vp
glprogs/nv20_diffuseColor.vp
glprogs/nv20_specularColor.vp
glprogs/nv20_diffuseAndSpecularColor.vp
glprogs/environment.vfp
glprogs/arbVP_glasswarp.txt: File not found
glprogs/arbFP_glasswarp.txt: File not found
glprogs/interactionUpdate.vfp
glprogs/interactionCubeMaps.vfp
glprogs/interactionNormBump.vfp
glprogs/interactionNormBumpH.vfp
glprogs/interactionAll.vfp
using ARB_vertex_buffer_object memory
using ARB2 renderSystem
found DLL in pak file: D:\Spill\PREY\base\game00.pk4/gamex86.dll
copy gamex86.dll to D:\Spill\PREY\base\gamex86.dll
3 22 640 480
Regenerated world, staticAllocCount = 0.
Shutting down sound hardware
idRenderSystem::Shutdown()
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...shutting down QGL
...unloading OpenGL DLL
wrong game DLL API version
Noen som vet hva som er mulig å gjøre?
Er ikke noe god på dette her, men for meg ser det ut som om det er noen av filene den ikke finner. Er du sikker på at du har nyeste DirectX? hvis ikke er det mulig at det vil hjelpe å reinstallere spillet
8823744[/snapback]
Har DirectX 9.0 og har installert 3 ganger nå
