Får ikke direct rendering i feisty
Hei.
Kjører feisty og har ett ATI Radeon Mobility X1600 i min laptop, har installert fglrx driverne etter denne guiden forsøkt begge metodene. Problemet er at når jeg skriver fglrxinfo får jeg:
Klikk for å se/fjerne innholdet nedenfor
martin@martin-laptop:~$ fglrxinfo
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.4 (1.5 Mesa 6.5.2)
og når jeg prøver xglinfo | grep direct kommer:
martin@martin-laptop:~$ glxinfo | grep direct
direct rendering: No
Her er min xorg.conf fil:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
       Identifier     "Default Layout"
       Screen         "Default Screen" 0 0
       InputDevice    "Generic Keyboard"
       InputDevice    "Configured Mouse"
       InputDevice    "stylus" "SendCoreEvents"
       InputDevice    "cursor" "SendCoreEvents"
       InputDevice    "eraser" "SendCoreEvents"
       InputDevice    "Synaptics Touchpad"
EndSection
Section "Files"
       # path to defoma fonts
       FontPath     "/usr/share/fonts/X11/misc"
       FontPath     "/usr/share/fonts/X11/cyrillic"
       FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
       FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
       FontPath     "/usr/share/fonts/X11/Type1"
       FontPath     "/usr/share/fonts/X11/100dpi"
       FontPath     "/usr/share/fonts/X11/75dpi"
       FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
       Load  "bitmap"
       Load  "ddc"
       Load  "dri"
       Load  "extmod"
       Load  "freetype"
       Load  "int10"
       Load  "vbe"
EndSection
Section "ServerFlags"
       Option      "AIGLX" "off"
EndSection
Section "InputDevice"
       Identifier  "Generic Keyboard"
       Driver      "kbd"
       Option      "CoreKeyboard"
       Option      "XkbRules" "xorg"
       Option      "XkbModel" "pc105"
       Option      "XkbLayout" "no"
       Option      "XkbOptions" "lv3:ralt_switch"
EndSection
       Identifier  "Configured Mouse"
       Driver      "mouse"
       Option      "CorePointer"
       Option      "Device" "/dev/input/mice"
       Option      "Protocol" "ImPS/2"
       Option      "ZAxisMapping" "4 5"
       Option      "Emulate3Buttons" "true"
EndSection
       Identifier  "Synaptics Touchpad"
       Driver      "synaptics"
       Option      "SendCoreEvents" "true"
       Option      "Device" "/dev/psaux"
       Option      "Protocol" "auto-dev"
       Option      "HorizScrollDelta" "0"
EndSection
       Identifier  "stylus"
       Driver      "wacom"
       Option      "Device" "/dev/input/wacom"
       Option      "Type" "stylus"
       Option      "ForceDevice" "ISDV4"# Tablet PC ONLY
EndSection
       Identifier  "eraser"
       Driver      "wacom"
       Option      "Type" "eraser"
EndSection
       Identifier  "cursor"
       Driver      "wacom"
       Option      "Type" "cursor"
EndSection
Section "Monitor"
       Identifier   "Standard skjerm"
       Option      "DPMS"
EndSection
Section "Device"
       Identifier  "ATI Radeon Mobility X1600"
       Driver      "fglrx"
       Option      "VideoOverlay" "on"
       Option      "OpenGLOverlay" "off"
       BusID       "PCI:1:0:0"
EndSection
Section "Screen"
       Identifier "Default Screen"
       Device     "ATI Radeon Mobility X1600"
       Monitor    "Standard skjerm"
       DefaultDepth     24
       SubSection "Display"
               Depth     1
               Modes    "1280x1024" "1280x960" "1280x854" "1280x800" "1280x768" "1200x800" "1152x864" "1152x768" "1024x768" "800x600" "640x480"
       EndSubSection
               Depth     4
       EndSubSection
               Depth     8
       EndSubSection
               Depth     15
       EndSubSection
               Depth     16
       EndSubSection
               Depth     24
       EndSubSection
EndSection
Section "DRI"
       Mode         0666
EndSection
Section "Extensions"
       Option      "Composite" "Disable"
EndSection
Da jeg hadde edgy fungerte direct rendering, men ikke nå. Dette er de nyeste ati driverne, installert manuelt. Noen som kan komme med noen forslag for å fikse dette? Disse skal vel fungere med 2.6.20 kjernen som feisty bruker?
På forhånd takk for alle svar.
Xorg.0.log
X Window System Version 7.2.0
Release Date: 22 January 2007
X Protocol Version 11, Revision 0, Release 7.2
Build Operating System: Linux Ubuntu
Current Operating System: Linux martin-laptop 2.6.20-15-generic #2 SMP Sun Apr 15 07:36:31 UTC 2007 i686
Build Date: 04 April 2007
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue May 22 23:11:47 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "Standard skjerm"
(**) |   |-->Device "ATI Radeon Mobility X1600"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "stylus"
(**) |-->Input Device "cursor"
(**) |-->Input Device "eraser"
(**) |-->Input Device "Synaptics Touchpad"
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
/usr/X11R6/lib/X11/fonts/misc,
/usr/share/fonts/X11/cyrillic,
/usr/X11R6/lib/X11/fonts/Type1,
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(**) Option "AIGLX" "off"
(**) Extension "Composite" is disabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81c92e0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.1
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.1
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,27a0 card 1043,1237 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,27a1 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:1b:0: chip 8086,27d8 card 1043,1123 rev 02 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,27d0 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:3: chip 8086,27d6 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,27c8 card 1043,1237 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,27c9 card 1043,1237 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,27ca card 1043,1237 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,27cb card 1043,1237 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,27cc card 1043,1237 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev e2 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,27b9 card 8086,27b9 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,27df card 1043,1237 rev 02 class 01,01,8a hdr 00
(II) PCI: 01:00:0: chip 1002,71c5 card 1043,10b2 rev 00 class 03,00,00 hdr 00
(II) PCI: 02:00:0: chip 10ec,8168 card 1043,11f5 rev 01 class 02,00,00 hdr 00
(II) PCI: 03:00:0: chip 8086,4222 card 8086,1001 rev 02 class 02,80,00 hdr 00
(II) PCI: 04:01:0: chip 1180,0476 card d000,0000 rev b3 class 06,07,00 hdr 82
(II) PCI: 04:01:1: chip 1180,0552 card 1043,1237 rev 08 class 0c,00,10 hdr 80
(II) PCI: 04:01:2: chip 1180,0822 card 1043,1237 rev 17 class 08,05,00 hdr 80
(II) PCI: 04:01:3: chip 1180,0592 card 1043,1237 rev 08 class 08,80,00 hdr 80
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1	0	0x00009000 - 0x0000bfff (0x3000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1	0	0xfdf00000 - 0xfdffffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1	0	0xbdf00000 - 0xddefffff (0x20000000) MX[B]
(II) Bus 2: bridge is at (0:28:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1	0	0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1	0	0xfe000000 - 0xfe0fffff (0x100000) MX[B]
(II) Bus 3: bridge is at (0:28:3), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 3 non-prefetchable memory range:
[0] -1	0	0xfe100000 - 0xfe1fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 4: bridge is at (0:30:0), (0,4,8), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1	0	0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 4 non-prefetchable memory range:
[0] -1	0	0xfe200000 - 0xfeafffff (0x900000) MX[B]
(II) Bus 4 prefetchable memory range:
[0] -1	0	0xddf00000 - 0xdfefffff (0x2000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-CardBus bridge:
(II) Bus 5: bridge is at (4:1:0), (4,5,8), BCTRL: 0x0580 (VGA_EN is cleared)
(II) Bus 5 I/O range:
[0] -1	0	0x0000d000 - 0x0000d0ff (0x100) IX[B]
[1] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[B]
(--) PCI:*(1:0:0) ATI Technologies Inc M56P [Radeon Mobility X1600] rev 0, Mem @ 0xc0000000/28, 0xfdff0000/16, I/O @ 0xb000/8, BIOS @ 0xfdfc0000/17
(II) Addressable bus resource ranges are
[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1	0	0xfeaff000 - 0xfeaff0ff (0x100) MX[B]
[1] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
[2] -1	0	0xfeaff800 - 0xfeafffff (0x800) MX[B]
[3] -1	0	0xfe1ff000 - 0xfe1fffff (0x1000) MX[B]
[4] -1	0	0xfe0ff000 - 0xfe0fffff (0x1000) MX[B]
[5] -1	0	0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
[6] -1	0	0xfebfc000 - 0xfebfffff (0x4000) MX[B]
[7] -1	0	0xfdfc0000 - 0xfdfdffff (0x20000) MX[B](B)
[8] -1	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B](B)
[9] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[10] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
[11] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[12] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
[13] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
[14] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
[15] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
[16] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
[17] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
[18] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
[19] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[20] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1	0	0xfeaff000 - 0xfeaff0ff (0x100) MX[B]
[5] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
[6] -1	0	0xfeaff800 - 0xfeafffff (0x800) MX[B]
[7] -1	0	0xfe1ff000 - 0xfe1fffff (0x1000) MX[B]
[8] -1	0	0xfe0ff000 - 0xfe0fffff (0x1000) MX[B]
[9] -1	0	0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
[10] -1	0	0xfebfc000 - 0xfebfffff (0x4000) MX[B]
[11] -1	0	0xfdfc0000 - 0xfdfdffff (0x20000) MX[B](B)
[12] -1	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B](B)
[13] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[14] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[15] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
[16] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
[17] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[18] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
[19] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
[20] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
[21] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
[22] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
[23] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
[24] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
[25] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[26] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules//libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.2.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.1.0
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.36.5
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 1.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.1.1
(II) LoadModule: "wacom"
(II) Loading /usr/lib/xorg/modules/input//wacom_drv.so
(II) Module wacom: vendor="X.Org Foundation"
compiled for 4.3.99.902, module version = 1.0.0
(II) Wacom driver level: 47-0.7.7-7 $
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.0
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.36.5
(II) ATI Proprietary Linux Driver Release Identifier: LGDr8.36g1
(II) ATI Proprietary Linux Driver Build Date: Apr 17 2007 10:04:24
(II) ATI Proprietary Linux Driver Build Information: autobuild-rel-r6-8.36.1.1.2.3-driver-lnx-x86-x86_64-338188
(--) Chipset Supported AMD Graphics Processor (0x71C5) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x81e4638
(II) resource ranges after probing:
[14] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
[15] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
[16] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
[17] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
[20] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[21] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
[22] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
[23] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
[24] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
[25] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
[26] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
[27] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
[28] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[29] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
[30] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
[31] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [atiddxPreInit] === begin, [x]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "DPMS"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) Reloading /usr/lib/xorg/modules//libint10.so
(II) Loading sub module "vm86"
(II) LoadModule: "vm86"
(II) Loading /usr/lib/xorg/modules//libvm86.so
(II) Module vm86: vendor="X.Org Foundation"
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(--) fglrx(0): Chipset: "ATI Mobility Radeon X1600" (Chipset = 0x71c5)
(--) fglrx(0): (PciSubVendor = 0x1043, PciSubDevice = 0x10b2)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xc0000000
(--) fglrx(0): MMIO registers at 0xfdff0000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) Loading sub module "vbe"
(II) Reloading /usr/lib/xorg/modules//libvbe.so
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 9.12
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: M56P
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
(WW) fglrx(0): Failed to open DRM connection
(--) fglrx(0): VideoRAM: 262144 kByte, Type: DDR2
(II) fglrx(0): PCIE card detected
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) Reloading /usr/lib/xorg/modules//libddc.so
(II) fglrx(0): Connected Display1: LCD on internal LVDS [lvds]
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: AUO  Model: 1974  Serial#: 0
(II) fglrx(0): Year: 2005  Week: 1
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Digital Display Input
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 33  vert.: 21
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): No DPMS capabilities specified; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.600 redY: 0.340   greenX: 0.310 greenY: 0.560
(II) fglrx(0): blueX: 0.150 blueY: 0.115   whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 68.9 MHz   Image Size:  331 x 207 mm
(II) fglrx(0): h_active: 1280  h_sync: 1301  h_sync_end 1333 h_blank_end 1408 h_border: 0
(II) fglrx(0): v_active: 800  v_sync: 804  v_sync_end 808 v_blanking: 816 v_border: 0
(II) fglrx(0):  AUO
(II) fglrx(0):  B154EW01 V9
(II) fglrx(0): EDID (in hex):
(II) fglrx(0):  00ffffffffffff0006af741900000000
(II) fglrx(0):  010f0103802115780a85a599574f8f26
(II) fglrx(0):  1d505400000001010101010101010101
(II) fglrx(0):  010101010101ea1a0080502010301520
(II) fglrx(0):  44004bcf100000180000000f00000000
(II) fglrx(0):  00000000000000000002000000fe0041
(II) fglrx(0):  554f0a202020202020202020000000fe
(II) fglrx(0):  004231353445573031205639200a00cc
(II) fglrx(0): End of Display1 EDID data --------------------
(II) fglrx(0): Primary Controller - LCD on internal LVDS
(II) fglrx(0): Internal Desktop Setting: 0x00000008
(II) fglrx(0): POWERplay version 3.  5 power states available:
(II) fglrx(0):   1. 452/351MHz @ 60Hz [enable load balancing]
(II) fglrx(0):   2. 128/135MHz @ 60Hz [low voltage, enable sleep]
(II) fglrx(0):   3. 209/135MHz @ 60Hz [low voltage, enable sleep]
(II) fglrx(0):   4. 324/135MHz @ 60Hz [low voltage, enable sleep]
(II) fglrx(0):   5. 392/252MHz @ 60Hz [enable sleep]
(==) fglrx(0): Qbs disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0):  PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 9 modes found for primary display.
(--) fglrx(0): Virtual size is 1280x800 (pitch 0)
(**) fglrx(0): *Mode "1280x800": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x800"   68.90  1280 1301 1333 1408  800 804 808 816 +hsync +vsync
(**) fglrx(0): *Mode "1024x768": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x768"   68.90  1024 1301 1333 1408  768 804 808 816 +hsync +vsync
(**) fglrx(0): *Mode "800x600": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "800x600"   68.90  800 1301 1333 1408  600 804 808 816 +hsync +vsync
(**) fglrx(0): *Mode "640x480": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x480"   68.90  640 1301 1333 1408  480 804 808 816 +hsync +vsync
(**) fglrx(0):  Default mode "640x400": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x400"   68.90  640 1301 1333 1408  400 804 808 816 +hsync +vsync
(**) fglrx(0):  Default mode "512x384": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "512x384"   68.90  512 1301 1333 1408  384 804 808 816 +hsync +vsync
(**) fglrx(0):  Default mode "400x300": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "400x300"   68.90  400 1301 1333 1408  300 804 808 816 +hsync +vsync
(**) fglrx(0):  Default mode "320x240": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "320x240"   68.90  320 1301 1333 1408  240 804 808 816 +hsync +vsync
(**) fglrx(0):  Default mode "320x200": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "320x200"   68.90  320 1301 1333 1408  200 804 808 816 +hsync +vsync
(--) fglrx(0): Display dimensions: (330, 210) mm
(--) fglrx(0): DPI set to (98, 96)
(--) fglrx(0): Virtual size is 1280x800 (pitch 1280)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/xorg/modules//libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
(==) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.2.0
(==) fglrx(0): HPV inactive
(==) fglrx(0): FSAA enabled: NO
(==) fglrx(0): FSAA Gamma enabled
(==) fglrx(0): FSAA Multisample Position is fix
(==) fglrx(0): NoDRI = NO
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(II) fglrx(0): Depth moves disabled by default
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x8000001d
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(**) fglrx(0): ATI GART size: 128 MB
(WW) fglrx(0): No DRM connection for driver fglrx.
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(==) fglrx(0): EnablePrivateBackZ = NO
(II) LoadModule: "glesx.so" (glesx)
(WW) LoadModule: given non-canonical module name "glesx.so"
(II) Loading /usr/lib/xorg/modules//glesx.so
(II) Module glesx: vendor="X.Org Foundation"
compiled for 7.1.0, module version = 1.0.0
(II) Loading extension GLESX
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
[0] 0	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B]
[1] 0	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B]
[2] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[3] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
[4] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
[5] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
[6] -1	0	0xfeaff000 - 0xfeaff0ff (0x100) MX[B]
[7] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
[8] -1	0	0xfeaff800 - 0xfeafffff (0x800) MX[B]
[9] -1	0	0xfe1ff000 - 0xfe1fffff (0x1000) MX[B]
[10] -1	0	0xfe0ff000 - 0xfe0fffff (0x1000) MX[B]
[11] -1	0	0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
[12] -1	0	0xfebfc000 - 0xfebfffff (0x4000) MX[B]
[13] -1	0	0xfdfc0000 - 0xfdfdffff (0x20000) MX[B](B)
[14] -1	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B](B)
[15] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[16] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B](OprU)
[17] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B](OprU)
[18] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B](OprU)
[19] 0	0	0x0000b000 - 0x0000b0ff (0x100) IX[B]
[20] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
[23] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[24] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
[25] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
[26] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
[27] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
[28] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
[29] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
[30] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
[31] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[32] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
[33] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[34] 0	0	0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
(II) fglrx(0): detected X.org 7.1.0.0
(II) Loading sub module "glx"
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(**) AIGLX disabled
(II) Loading extension GLX
(EE) fglrx(0): GART is not initialized, disabling DRI
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed!                  *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO)             *
(WW) fglrx(0): * no 3D acceleration available                *
(WW) fglrx(0): ********************************************* *
(II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x10000000
(==) fglrx(0): Write-combining range (0xc0000000,0x10000000)
(II) fglrx(0): FBMM initialized for area (0,0)-(1280,8191)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1280,800) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1280 x 7391
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(**) fglrx(0): DPMS enabled
(WW) fglrx(0): Textured Video not supported without DRI enabled.
(WW) fglrx(0): Video Overlay not supported on AVIVO based graphics cards. For XVideo support use Option "TexturedVideo".
(II) fglrx(0): GLESX enableFlags = 0
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid Horizontal and Vertical Lines
Offscreen Pixmaps
Setting up tile and stipple cache:
 32 128x128 slots
 32 256x256 slots
 16 512x512 slots
(II) fglrx(0): Acceleration enabled
(II) fglrx(0): Direct rendering disabled
(==) fglrx(0): Using hardware cursor
fbarea0->box.x1 0x00000000, fbarea0->box.y1 0x00000324
fbarea0->box.x2 0x00000500, fbarea0->box.y2 0x00000326
icon[0].start=0x3ed000
fbarea1->box.x1 0x00000000, fbarea1->box.y1 0x00000326
fbarea1->box.x2 0x00000500, fbarea1->box.y2 0x00000328
icon[1].start=0x3f0000
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
[glesx] __glESXExtensionInit: No GL ES2.0 capable screen found!
(II) Loading local sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(**) Option "CoreKeyboard"
(**) Generic Keyboard: Core Keyboard
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Generic Keyboard: XkbModel: "pc105"
(**) Option "XkbLayout" "no"
(**) Generic Keyboard: XkbLayout: "no"
(**) Option "XkbOptions" "lv3:ralt_switch"
(**) Generic Keyboard: XkbOptions: "lv3:ralt_switch"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 9
(**) Option "SendCoreEvents"
(**) stylus: always reports core events
(**) stylus device is /dev/input/wacom
(**) stylus is in absolute mode
(**) stylus: forcing TabletPC ISD V4 protocol
(**) WACOM: suppress value is 2
(**) Option "BaudRate" "9600"
(**) stylus: serial speed 9600
(**) cursor: always reports core events
(**) cursor device is /dev/input/wacom
(**) cursor is in relative mode
(**) cursor: forcing TabletPC ISD V4 protocol
(**) cursor: serial speed 9600
(**) eraser: always reports core events
(**) eraser device is /dev/input/wacom
(**) eraser is in absolute mode
(**) eraser: forcing TabletPC ISD V4 protocol
(**) eraser: serial speed 9600
(II) Synaptics touchpad driver version 0.14.6 (1406)
(--) Synaptics Touchpad auto-dev sets device to /dev/input/event4
(**) Option "Device" "/dev/input/event4"
(**) Option "HorizScrollDelta" "0"
(--) Synaptics Touchpad touchpad found
(**) Option "SendCoreEvents" "true"
(**) Synaptics Touchpad: always reports core events
(II) XINPUT: Adding extended input device "Synaptics Touchpad" (type: MOUSE)
(II) XINPUT: Adding extended input device "eraser" (type: Wacom Eraser)
(II) XINPUT: Adding extended input device "cursor" (type: Wacom Cursor)
(II) XINPUT: Adding extended input device "stylus" (type: Wacom Stylus)
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(**) Option "Device" "/dev/input/wacom"
(EE) xf86OpenSerial: Cannot open device /dev/input/wacom
No such file or directory.
Error opening /dev/input/wacom : Invalid argument
Synaptics DeviceInit called
SynapticsCtrl called.
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Synaptics DeviceOn called
Could not init font path element /usr/X11R6/lib/X11/fonts/misc, removing from list!
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/Type1, removing from list!
ProcXCloseDevice to close or not ?
SetGrabKeysState - disabled
SetGrabKeysState - enabled
Har googlet litt på feilmeldingen du får:
Viser seg at det skjer med alle distroer, bortsett fra distroer som bare bruker "vanilla" pakker(arch/slackware o.l.), prøv "method 2" i how to'en, og se om det hvirker, avinstaller først driveren du installerte med apt.
Endret av roberth1990
Ok, er ikke veldig farlig, bare litt surt å ikke få spilt Q4 atm. Har uansett planer om å bytte til arch så fort jeg får meg sommerferie, så da får jeg få det til å funke skikkelig.
Fant ut hva det var, feisty bruker Xorg 7.2, mens ATI driverne kun støtter opp til Xorg 7.1. Forsøkte å nedgradere til 7.1, men da ville plutselig ikke xserver starte. Så får innstallere med Xorg 7.1 da jeg innstallerer arch etter eksamener, forutsatt at ikke ati har klart å komme med nye drivere da selvsagt.
Forsøkte alle tipsene ovenfor, pluss jeg forsøkte å innstallere det manuelt etter en guide fra en venn av meg, ingenting har fungert. Under Package Includes står det jo bare:
Automated installer and Display Drivers for XFree86 4.3 and X.Org 6.7, 6.8, 6.9, 7.0, 7.1
Altså er 7.2 utelatt.
Så nå at den skal støtte 7.2 fra v. 8.33.6.
8683069[/snapback]
Det finnes ingen offisiell støtte for 7.2, men det skal likevel fungere i ubuntu (ubuntu folka har patchet det slik at det fungerer).
Du prøvde å legge til Load "glx" i "Modules" ?
8683125[/snapback]
Jepp.
Hmmm... Så nå nettopp i System->Administration->Restricted Drivers at ATI accelrated graphics driver sto som "Not in use". Er det bare dette som er feilen? Hvordan får jeg lastet de inn og brukt de?
Takk for alle svar så langt ;)
Endret av NevroMance
