NWN2 freedom of movement?
Har spillt NWN2 en del og prøvd masse forskjelige classes og sånn, men jeg har aldri skjønt hva "freedom of movement" er :hmm: ... Står som bonus på kapper og ringer og sånn.. noen som vet? skulle gjerne likt å visst...
takk på forhånd :thumbup:
d20srd:
Freedom of Movement:
This spell enables you or a creature you touch to move and attack normally for the duration of the spell, even under the influence of magic that usually impedes movement, such as paralysis, solid fog, slow, and web. The subject automatically succeeds on any grapple check made to resist a grapple attempt, as well as on grapple checks or Escape Artist checks made to escape a grapple or a pin.
The spell also allows the subject to move and attack normally while underwater, even with slashing weapons such as axes and swords or with bludgeoning weapons such as flails, hammers, and maces, provided that the weapon is wielded in the hand rather than hurled. The freedom of movement spell does not, however, allow water breathing.
Den undervanns biten gjelder riktig nok ikke i Nwn2 men sier litt om hvor bra spellen er :roll:
Er ufattelig bra btw.. hjelper som pokker ettersom det og bli roota mens du blir bombadert med spells eller piler er ikke bra, eller bli slowa så du mister ett angrep per runde suger noe kraftig.
