Feil i filsystemet på ekstern harddisk?
Dette er trolig feilpostet siden det sannsynligvis er en hardwarefeil, men jeg poster her i håp om at det er en feil i filsystemet eller noe liknende. :)
Jeg prøver å mounte min eksterne usbdisk , ingen output blir gitt og ingen harddisk blir mountet.
dmesg gir følgende resultat:
Klikk for å se/fjerne innholdet nedenfor
[17198075.588000] usb 4-1: new high speed USB device using ehci_hcd and address 6
[17198075.720000] usb 4-1: configuration #1 chosen from 1 choice
[17198075.720000] scsi2 : SCSI emulation for USB Mass Storage devices
[17198075.720000] usb-storage: device found at 6
[17198075.720000] usb-storage: waiting for device to settle before scanning
[17198080.720000] usb-storage: device scan complete
[17198083.352000] Vendor: HDT72252 Model: 5DLAT80 Rev: 0 0
[17198083.352000] Type: Direct-Access ANSI SCSI revision: 00
[17198083.356000] SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
[17198083.356000] sda: Write Protect is off
[17198083.356000] sda: Mode Sense: 33 00 00 00
[17198083.356000] sda: assuming drive cache: write through
[17198083.356000] sda:<6>sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.396000] sda: Current: sense key: Aborted Command
[17198083.396000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.396000] end_request: I/O error, dev sda, sector 0
[17198083.396000] Buffer I/O error on device sda, logical block 0
[17198083.408000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.408000] sda: Current: sense key: Aborted Command
[17198083.408000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.408000] end_request: I/O error, dev sda, sector 0
[17198083.408000] Buffer I/O error on device sda, logical block 0
[17198083.408000] unable to read partition table
[17198083.412000] sd 2:0:0:0: Attached scsi disk sda
[17198083.412000] sd 2:0:0:0: Attached scsi generic sg0 type 0
[17198083.692000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.692000] sda: Current: sense key: Aborted Command
[17198083.692000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.692000] end_request: I/O error, dev sda, sector 488396928
[17198083.692000] Buffer I/O error on device sda, logical block 61049616
[17198083.708000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.708000] sda: Current: sense key: Aborted Command
[17198083.708000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.708000] end_request: I/O error, dev sda, sector 488396928
[17198083.708000] Buffer I/O error on device sda, logical block 61049616
[17198083.724000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.724000] sda: Current: sense key: Aborted Command
[17198083.724000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.724000] end_request: I/O error, dev sda, sector 488397160
[17198083.724000] Buffer I/O error on device sda, logical block 61049645
[17198083.740000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.740000] sda: Current: sense key: Aborted Command
[17198083.740000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.740000] end_request: I/O error, dev sda, sector 488397160
[17198083.740000] Buffer I/O error on device sda, logical block 61049645
[17198083.756000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.756000] sda: Current: sense key: Aborted Command
[17198083.756000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.756000] end_request: I/O error, dev sda, sector 488397160
[17198083.756000] Buffer I/O error on device sda, logical block 61049645
[17198083.772000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.772000] sda: Current: sense key: Aborted Command
[17198083.772000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.772000] end_request: I/O error, dev sda, sector 488397160
[17198083.772000] Buffer I/O error on device sda, logical block 61049645
[17198083.788000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.788000] sda: Current: sense key: Aborted Command
[17198083.788000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.788000] end_request: I/O error, dev sda, sector 488397160
[17198083.788000] Buffer I/O error on device sda, logical block 61049645
[17198083.808000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.808000] sda: Current: sense key: Aborted Command
[17198083.808000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.808000] end_request: I/O error, dev sda, sector 488397160
[17198083.808000] Buffer I/O error on device sda, logical block 61049645
[17198083.824000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.824000] sda: Current: sense key: Aborted Command
[17198083.824000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.824000] end_request: I/O error, dev sda, sector 488397104
[17198083.840000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.840000] sda: Current: sense key: Aborted Command
[17198083.840000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.840000] end_request: I/O error, dev sda, sector 488397104
[17198083.856000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.856000] sda: Current: sense key: Aborted Command
[17198083.856000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.856000] end_request: I/O error, dev sda, sector 488397152
[17198083.876000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.876000] sda: Current: sense key: Aborted Command
[17198083.876000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.876000] end_request: I/O error, dev sda, sector 488397152
[17198083.896000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.896000] sda: Current: sense key: Aborted Command
[17198083.896000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.896000] end_request: I/O error, dev sda, sector 488397160
[17198083.912000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.912000] sda: Current: sense key: Aborted Command
[17198083.912000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.912000] end_request: I/O error, dev sda, sector 488397160
[17198083.928000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.928000] sda: Current: sense key: Aborted Command
[17198083.928000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.928000] end_request: I/O error, dev sda, sector 0
[17198083.944000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.944000] sda: Current: sense key: Aborted Command
[17198083.944000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.944000] end_request: I/O error, dev sda, sector 0
[17198083.960000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.960000] sda: Current: sense key: Aborted Command
[17198083.960000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.960000] end_request: I/O error, dev sda, sector 0
[17198083.976000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.976000] sda: Current: sense key: Aborted Command
[17198083.976000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.976000] end_request: I/O error, dev sda, sector 0
[17198083.992000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198083.992000] sda: Current: sense key: Aborted Command
[17198083.992000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198083.992000] end_request: I/O error, dev sda, sector 8
[17198084.008000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.008000] sda: Current: sense key: Aborted Command
[17198084.008000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.008000] end_request: I/O error, dev sda, sector 16
[17198084.020000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.020000] sda: Current: sense key: Aborted Command
[17198084.020000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.020000] end_request: I/O error, dev sda, sector 24
[17198084.036000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.036000] sda: Current: sense key: Aborted Command
[17198084.036000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.036000] end_request: I/O error, dev sda, sector 32
[17198084.052000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.052000] sda: Current: sense key: Aborted Command
[17198084.052000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.052000] end_request: I/O error, dev sda, sector 0
[17198084.068000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.068000] sda: Current: sense key: Aborted Command
[17198084.068000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.068000] end_request: I/O error, dev sda, sector 0
[17198084.080000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.080000] sda: Current: sense key: Aborted Command
[17198084.080000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.080000] end_request: I/O error, dev sda, sector 0
[17198084.108000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.108000] sda: Current: sense key: Aborted Command
[17198084.108000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.108000] end_request: I/O error, dev sda, sector 40
[17198084.132000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.132000] sda: Current: sense key: Aborted Command
[17198084.132000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.132000] end_request: I/O error, dev sda, sector 48
[17198084.156000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.156000] sda: Current: sense key: Aborted Command
[17198084.156000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.156000] end_request: I/O error, dev sda, sector 56
[17198084.180000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.180000] sda: Current: sense key: Aborted Command
[17198084.180000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.180000] end_request: I/O error, dev sda, sector 64
[17198084.204000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.204000] sda: Current: sense key: Aborted Command
[17198084.204000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.204000] end_request: I/O error, dev sda, sector 72
[17198084.228000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.228000] sda: Current: sense key: Aborted Command
[17198084.228000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.228000] end_request: I/O error, dev sda, sector 80
[17198084.248000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.248000] sda: Current: sense key: Aborted Command
[17198084.248000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.248000] end_request: I/O error, dev sda, sector 88
[17198084.272000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.272000] sda: Current: sense key: Aborted Command
[17198084.272000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.272000] end_request: I/O error, dev sda, sector 96
[17198084.292000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.292000] sda: Current: sense key: Aborted Command
[17198084.292000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.292000] end_request: I/O error, dev sda, sector 104
[17198084.316000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.316000] sda: Current: sense key: Aborted Command
[17198084.316000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.316000] end_request: I/O error, dev sda, sector 112
[17198084.336000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.336000] sda: Current: sense key: Aborted Command
[17198084.336000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.336000] end_request: I/O error, dev sda, sector 120
[17198084.356000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.356000] sda: Current: sense key: Aborted Command
[17198084.356000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.356000] end_request: I/O error, dev sda, sector 128
[17198084.376000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.376000] sda: Current: sense key: Aborted Command
[17198084.376000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.376000] end_request: I/O error, dev sda, sector 136
[17198084.396000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.396000] sda: Current: sense key: Aborted Command
[17198084.396000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.396000] end_request: I/O error, dev sda, sector 144
[17198084.416000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.416000] sda: Current: sense key: Aborted Command
[17198084.416000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.416000] end_request: I/O error, dev sda, sector 152
[17198084.436000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.436000] sda: Current: sense key: Aborted Command
[17198084.436000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.436000] end_request: I/O error, dev sda, sector 160
[17198084.452000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.452000] sda: Current: sense key: Aborted Command
[17198084.452000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.452000] end_request: I/O error, dev sda, sector 168
[17198084.472000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.472000] sda: Current: sense key: Aborted Command
[17198084.472000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.472000] end_request: I/O error, dev sda, sector 176
[17198084.488000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.488000] sda: Current: sense key: Aborted Command
[17198084.488000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.488000] end_request: I/O error, dev sda, sector 184
[17198084.508000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.508000] sda: Current: sense key: Aborted Command
[17198084.508000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.508000] end_request: I/O error, dev sda, sector 192
[17198084.524000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.524000] sda: Current: sense key: Aborted Command
[17198084.524000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.524000] end_request: I/O error, dev sda, sector 200
[17198084.540000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.540000] sda: Current: sense key: Aborted Command
[17198084.540000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.540000] end_request: I/O error, dev sda, sector 208
[17198084.556000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.556000] sda: Current: sense key: Aborted Command
[17198084.556000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.556000] end_request: I/O error, dev sda, sector 216
[17198084.572000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.572000] sda: Current: sense key: Aborted Command
[17198084.572000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.572000] end_request: I/O error, dev sda, sector 224
[17198084.588000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.588000] sda: Current: sense key: Aborted Command
[17198084.588000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.588000] end_request: I/O error, dev sda, sector 232
[17198084.604000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.604000] sda: Current: sense key: Aborted Command
[17198084.604000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.604000] end_request: I/O error, dev sda, sector 240
[17198084.620000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.620000] sda: Current: sense key: Aborted Command
[17198084.620000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.620000] end_request: I/O error, dev sda, sector 248
[17198084.636000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.636000] sda: Current: sense key: Aborted Command
[17198084.636000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.636000] end_request: I/O error, dev sda, sector 256
[17198084.648000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.648000] sda: Current: sense key: Aborted Command
[17198084.648000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.648000] end_request: I/O error, dev sda, sector 0
[17198084.664000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.664000] sda: Current: sense key: Aborted Command
[17198084.664000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.664000] end_request: I/O error, dev sda, sector 0
[17198084.680000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.680000] sda: Current: sense key: Aborted Command
[17198084.680000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.680000] end_request: I/O error, dev sda, sector 0
[17198084.696000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.696000] sda: Current: sense key: Aborted Command
[17198084.696000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.696000] end_request: I/O error, dev sda, sector 0
[17198084.712000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.712000] sda: Current: sense key: Aborted Command
[17198084.712000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.712000] end_request: I/O error, dev sda, sector 0
[17198084.728000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.728000] sda: Current: sense key: Aborted Command
[17198084.728000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.728000] end_request: I/O error, dev sda, sector 0
[17198084.744000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.744000] sda: Current: sense key: Aborted Command
[17198084.744000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.744000] end_request: I/O error, dev sda, sector 0
[17198084.760000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.760000] sda: Current: sense key: Aborted Command
[17198084.760000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.760000] end_request: I/O error, dev sda, sector 0
[17198084.776000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.776000] sda: Current: sense key: Aborted Command
[17198084.776000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.776000] end_request: I/O error, dev sda, sector 0
[17198084.788000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.788000] sda: Current: sense key: Aborted Command
[17198084.788000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.788000] end_request: I/O error, dev sda, sector 0
[17198084.804000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.804000] sda: Current: sense key: Aborted Command
[17198084.804000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.804000] end_request: I/O error, dev sda, sector 0
[17198084.820000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.820000] sda: Current: sense key: Aborted Command
[17198084.820000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.820000] end_request: I/O error, dev sda, sector 0
[17198084.836000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.836000] sda: Current: sense key: Aborted Command
[17198084.836000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.836000] end_request: I/O error, dev sda, sector 0
[17198084.852000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.852000] sda: Current: sense key: Aborted Command
[17198084.852000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.852000] end_request: I/O error, dev sda, sector 0
[17198084.868000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.868000] sda: Current: sense key: Aborted Command
[17198084.868000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.868000] end_request: I/O error, dev sda, sector 0
[17198084.884000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.884000] sda: Current: sense key: Aborted Command
[17198084.884000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.884000] end_request: I/O error, dev sda, sector 0
[17198084.900000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.900000] sda: Current: sense key: Aborted Command
[17198084.900000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.900000] end_request: I/O error, dev sda, sector 0
[17198084.912000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.912000] sda: Current: sense key: Aborted Command
[17198084.912000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.912000] end_request: I/O error, dev sda, sector 0
[17198084.932000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.932000] sda: Current: sense key: Aborted Command
[17198084.932000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.932000] end_request: I/O error, dev sda, sector 0
[17198084.944000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198084.944000] sda: Current: sense key: Aborted Command
[17198084.944000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198084.944000] end_request: I/O error, dev sda, sector 0
[17198085.108000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.108000] sda: Current: sense key: Aborted Command
[17198085.108000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.108000] end_request: I/O error, dev sda, sector 0
[17198085.124000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.124000] sda: Current: sense key: Aborted Command
[17198085.124000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.124000] end_request: I/O error, dev sda, sector 8
[17198085.140000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.140000] sda: Current: sense key: Aborted Command
[17198085.140000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.140000] end_request: I/O error, dev sda, sector 16
[17198085.152000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.152000] sda: Current: sense key: Aborted Command
[17198085.152000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.152000] end_request: I/O error, dev sda, sector 24
[17198085.168000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.168000] sda: Current: sense key: Aborted Command
[17198085.168000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.168000] end_request: I/O error, dev sda, sector 0
[17198085.184000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.184000] sda: Current: sense key: Aborted Command
[17198085.184000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.184000] end_request: I/O error, dev sda, sector 0
[17198085.200000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.200000] sda: Current: sense key: Aborted Command
[17198085.200000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.200000] end_request: I/O error, dev sda, sector 32
[17198085.220000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.220000] sda: Current: sense key: Aborted Command
[17198085.220000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.220000] end_request: I/O error, dev sda, sector 40
[17198085.236000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.236000] sda: Current: sense key: Aborted Command
[17198085.236000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.236000] end_request: I/O error, dev sda, sector 48
[17198085.252000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.252000] sda: Current: sense key: Aborted Command
[17198085.252000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.252000] end_request: I/O error, dev sda, sector 56
[17198085.268000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.268000] sda: Current: sense key: Aborted Command
[17198085.268000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.268000] end_request: I/O error, dev sda, sector 64
[17198085.280000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.280000] sda: Current: sense key: Aborted Command
[17198085.280000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.280000] end_request: I/O error, dev sda, sector 72
[17198085.296000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.296000] sda: Current: sense key: Aborted Command
[17198085.296000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.296000] end_request: I/O error, dev sda, sector 80
[17198085.312000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.312000] sda: Current: sense key: Aborted Command
[17198085.312000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.312000] end_request: I/O error, dev sda, sector 88
[17198085.328000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.328000] sda: Current: sense key: Aborted Command
[17198085.328000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.328000] end_request: I/O error, dev sda, sector 0
[17198085.340000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.340000] sda: Current: sense key: Aborted Command
[17198085.340000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.340000] end_request: I/O error, dev sda, sector 0
[17198085.356000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.356000] sda: Current: sense key: Aborted Command
[17198085.356000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.356000] end_request: I/O error, dev sda, sector 0
[17198085.380000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.380000] sda: Current: sense key: Aborted Command
[17198085.380000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.380000] end_request: I/O error, dev sda, sector 0
[17198085.400000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.400000] sda: Current: sense key: Aborted Command
[17198085.400000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.400000] end_request: I/O error, dev sda, sector 96
[17198085.424000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.424000] sda: Current: sense key: Aborted Command
[17198085.424000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.424000] end_request: I/O error, dev sda, sector 104
[17198085.444000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.444000] sda: Current: sense key: Aborted Command
[17198085.444000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.444000] end_request: I/O error, dev sda, sector 112
[17198085.468000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.468000] sda: Current: sense key: Aborted Command
[17198085.468000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.468000] end_request: I/O error, dev sda, sector 120
[17198085.488000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.488000] sda: Current: sense key: Aborted Command
[17198085.488000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.488000] end_request: I/O error, dev sda, sector 128
[17198085.508000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.508000] sda: Current: sense key: Aborted Command
[17198085.508000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.508000] end_request: I/O error, dev sda, sector 136
[17198085.528000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.528000] sda: Current: sense key: Aborted Command
[17198085.528000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.528000] end_request: I/O error, dev sda, sector 144
[17198085.544000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.544000] sda: Current: sense key: Aborted Command
[17198085.544000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.544000] end_request: I/O error, dev sda, sector 152
[17198085.564000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.564000] sda: Current: sense key: Aborted Command
[17198085.564000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.564000] end_request: I/O error, dev sda, sector 160
[17198085.584000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.584000] sda: Current: sense key: Aborted Command
[17198085.584000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.584000] end_request: I/O error, dev sda, sector 168
[17198085.600000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.600000] sda: Current: sense key: Aborted Command
[17198085.600000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.600000] end_request: I/O error, dev sda, sector 176
[17198085.620000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.620000] sda: Current: sense key: Aborted Command
[17198085.620000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.620000] end_request: I/O error, dev sda, sector 184
[17198085.636000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.636000] sda: Current: sense key: Aborted Command
[17198085.636000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.636000] end_request: I/O error, dev sda, sector 192
[17198085.656000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.656000] sda: Current: sense key: Aborted Command
[17198085.656000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.656000] end_request: I/O error, dev sda, sector 200
[17198085.672000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.672000] sda: Current: sense key: Aborted Command
[17198085.672000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.672000] end_request: I/O error, dev sda, sector 208
[17198085.688000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.688000] sda: Current: sense key: Aborted Command
[17198085.688000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.688000] end_request: I/O error, dev sda, sector 216
[17198085.704000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.704000] sda: Current: sense key: Aborted Command
[17198085.704000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.704000] end_request: I/O error, dev sda, sector 224
[17198085.720000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.720000] sda: Current: sense key: Aborted Command
[17198085.720000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.720000] end_request: I/O error, dev sda, sector 232
[17198085.736000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.736000] sda: Current: sense key: Aborted Command
[17198085.736000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.736000] end_request: I/O error, dev sda, sector 240
[17198085.748000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.748000] sda: Current: sense key: Aborted Command
[17198085.748000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.748000] end_request: I/O error, dev sda, sector 248
[17198085.764000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.764000] sda: Current: sense key: Aborted Command
[17198085.764000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.764000] end_request: I/O error, dev sda, sector 256
[17198085.780000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.780000] sda: Current: sense key: Aborted Command
[17198085.780000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.780000] end_request: I/O error, dev sda, sector 0
[17198085.792000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.792000] sda: Current: sense key: Aborted Command
[17198085.792000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.792000] end_request: I/O error, dev sda, sector 0
[17198085.808000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.808000] sda: Current: sense key: Aborted Command
[17198085.808000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.808000] end_request: I/O error, dev sda, sector 0
[17198085.824000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.824000] sda: Current: sense key: Aborted Command
[17198085.824000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.824000] end_request: I/O error, dev sda, sector 0
[17198085.840000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.840000] sda: Current: sense key: Aborted Command
[17198085.840000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.840000] end_request: I/O error, dev sda, sector 0
[17198085.856000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.856000] sda: Current: sense key: Aborted Command
[17198085.856000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.856000] end_request: I/O error, dev sda, sector 0
[17198085.872000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.872000] sda: Current: sense key: Aborted Command
[17198085.872000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.872000] end_request: I/O error, dev sda, sector 0
[17198085.888000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.888000] sda: Current: sense key: Aborted Command
[17198085.888000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.888000] end_request: I/O error, dev sda, sector 0
[17198085.904000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.904000] sda: Current: sense key: Aborted Command
[17198085.904000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.904000] end_request: I/O error, dev sda, sector 0
[17198085.920000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.920000] sda: Current: sense key: Aborted Command
[17198085.920000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.920000] end_request: I/O error, dev sda, sector 0
[17198085.936000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.936000] sda: Current: sense key: Aborted Command
[17198085.936000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.936000] end_request: I/O error, dev sda, sector 0
[17198085.952000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.952000] sda: Current: sense key: Aborted Command
[17198085.952000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.952000] end_request: I/O error, dev sda, sector 0
[17198085.968000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.968000] sda: Current: sense key: Aborted Command
[17198085.968000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.968000] end_request: I/O error, dev sda, sector 0
[17198085.984000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.984000] sda: Current: sense key: Aborted Command
[17198085.984000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.984000] end_request: I/O error, dev sda, sector 0
[17198085.996000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198085.996000] sda: Current: sense key: Aborted Command
[17198085.996000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198085.996000] end_request: I/O error, dev sda, sector 0
[17198086.020000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198086.020000] sda: Current: sense key: Aborted Command
[17198086.020000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198086.020000] end_request: I/O error, dev sda, sector 0
[17198086.036000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198086.036000] sda: Current: sense key: Aborted Command
[17198086.036000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198086.036000] end_request: I/O error, dev sda, sector 0
[17198086.052000] sd 2:0:0:0: SCSI error: return code = 0x8000002
[17198086.052000] sda: Current: sense key: Aborted Command
[17198086.052000] Additional sense: Logical unit communication CRC error (Ultra-DMA/32)
[17198086.052000] end_request: I/O error, dev sda, sector 0
Filsystemet på disken er fat32.
$ fsck -t vfat /dev/sda1
fsck 1.39 (29-May-2006)
dosfsck 2.11, 12 Mar 2005, FAT32, LFN
Read 512 bytes at 0:Input/output error
-Wiley
Jeg har ikke mye peiling på dette, men CRC error tyder jo på noe feil med hw'en din, gjør det ikke?.. Derfor ville jeg prøvd å formatere den på nytt.
Takker og bukker for all hjelp! Om det er en hardwarefeil hjelper det kanskje ikke å reformatere, men jeg må nok bite i det sure eplet og prøve, trass i masse informasjon jeg ikke har back-up av ...
-Wiley
