Django Skrevet 24. mars 2007 Skrevet 24. mars 2007 Hei, har prøvet å lage en "bot" som automatiserer en brukeropprettelse via ett admininterface jeg har en konto på, den skal lage subaccounts ved å feks besøke http://minurl.com/account_setup.php?ident=...assord=testpass Koden: <?php // Logg inn på siden og lagre session id og cookies $post = 'user=2791&pw=*sensurert*&lang=english'; $cookie_file_path = "output.txt"; $curl = curl_init(); curl_setopt($curl, CURLOPT_POST, 1); curl_setopt($curl, CURLOPT_FOLLOWLOCATION, 1); curl_setopt ($curl, CURLOPT_USERAGENT, "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8b)"); curl_setopt($curl, CURLOPT_URL,"https://www.bouncer-interface.de/?"); curl_setopt($curl, CURLOPT_COOKIEFILE, $cookie_file_path); curl_setopt($curl, CURLOPT_COOKIEJAR, $cookie_file_path); curl_setopt($curl, CURLOPT_POSTFIELDS, $post); curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, FALSE); curl_setopt ($curl, CURLOPT_RETURNTRANSFER, 1); $result = curl_exec($curl); echo("Resultat: <br>".$result); // Post 2, Når vi er logget inn >lag en ny sub account i interfacet med get's // Hente session id og cookies fra forrige post $post1 = 'ident='.$_GET['ident']&username.'='.$_GET['nick'].'&pw='.$_GET['passord'].'&server=4343&vhost=ist.ein.bot.nu&awaymsg=away&awaynick='.$_GET['nick'].'&leavemsg=lol&irc-server=underworld.no.quakenet.org&irc-port=6667'; curl_setopt($curl, CURLOPT_POST, 1); curl_setopt($curl, CURLOPT_FOLLOWLOCATION, 1); curl_setopt ($curl, CURLOPT_USERAGENT, "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8b)"); curl_setopt($curl, CURLOPT_URL,"https://www.bouncer-interface.de/?modul=psybnc&a=adduser"); curl_setopt($curl, CURLOPT_COOKIEFILE, $cookie_file_path); curl_setopt($curl, CURLOPT_COOKIEJAR, $cookie_file_path); curl_setopt($curl, CURLOPT_POSTFIELDS, $post1); curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, FALSE); curl_setopt ($curl, CURLOPT_RETURNTRANSFER, 1); $result = curl_exec($curl); echo("Resultat: <br>".$result); // Hele poenget, automatisering. /* ved å skrive http://myurl.net/setup_bnc.php?ident=40&nick=Xstasy&passord=testpass */ curl_close ($curl); ?> Jeg får ingen error når jeg åpner siden, det kommer heller ingenting i output.txt Men det skjer ingenting i interfacet når jeg sjekker etterpå, altså ingen konto ble opprettet. Info: PHP/4.4.2 CURL support: enabled CURL Information: libcurl/7.15.3 OpenSSL/0.9.7e Vært kjempefint om dere hadde noen løsninger på dette, har sett gjennom forumposter over alt i hele natt uten å finne noen løsninger på mitt problem.
VisualStudio Skrevet 26. april 2007 Skrevet 26. april 2007 Jeg kan ikke språket med det kan jo hende du må chmodde output.txt 777 ?
Runar0 Skrevet 26. april 2007 Skrevet 26. april 2007 (endret) Du kan prøve og skrive error_reporting(E_ALL); på toppen og se om du får noen feilmeldinger. Og prøve å chmodde output.txt slik som VisualStudio sa. Endret 26. april 2007 av Shadows0
Rasks Skrevet 26. april 2007 Skrevet 26. april 2007 Gjorde noen endringer i "Post nr 1", får i hvertfall feilmelding om "Login failed!" fordi jeg ikke har riktig passord. <?php $post = "user=2791&pw=sensurert&lang=english&submit=Login!"; $cookie_file_path = "/output.txt"; $curl = curl_init(); curl_setopt ($curl, CURLOPT_USERAGENT, "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8b)"); curl_setopt($curl, CURLOPT_URL, "https://www.bouncer-interface.de/?"); curl_setopt($curl, CURLOPT_COOKIEFILE, $cookie_file_path); curl_setopt($curl, CURLOPT_COOKIEJAR, $cookie_file_path); curl_setopt($curl, CURLOPT_RETURNTRANSFER, 0); curl_setopt($curl, CURLOPT_FOLLOWLOCATION, 1); curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, FALSE); curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, 0); curl_setopt($curl, CURLOPT_HEADER, 1); curl_setopt($curl, CURLOPT_POST, 1); curl_setopt($curl, CURLOPT_POSTFIELDS, $post); curl_exec($curl); curl_close ($curl); ?> Dette er bare første del, husk å bruke det absolutte filnavnet til output.txt.
