Smøring til Saitek X45
Jeg lurer på om noen har tips til hvilket smøremiddel jeg kan bruke (plast mot plast) for å få X45en min til å bli litt "smoothere". Håper noen vet...
noko eg kom over
The type of grease i use in the white grease i found in rc hobby servos. It is a grease for plastic gears. I actually disassemble a hobby servo and salvage some grease from the gears for this job. You can also find this grease in some vhs video players or some casset tape players, where ever there are plastic gears. Dont use WD-40 or machine oil. It will sqeak again in a few days.
now over weeks of use the greased joystick is still very easy to use. It feels much lighter on the finger and no sqeaks. I dont have to use as much effort to move the joystick nub anymore
