Smart FTP - Problemer med errors
AnaXyd
Hei!
Jeg driver å laster opp store mengder med data opp mot en FTP host nå, og bruker SmartFTP til det.
Problemet er at SmartFTP kutter ut etterhvert, og kommer med "Transfer Error"
Dette er litt irriterende, da jeg må sette den til å laste opp igjen.
Dette skjer da omtrent hvert 2. min. Det kan da bli veldig langtrekkelig å laste opp større mengder med data, da jeg må slite og klundre med dette, og passe på den hele tida.
Slik ser det ut i SmartFTP når den har stoppet: (Har sensurert bort diverse ip'er og urls med *)
STOR skin_global.php
[14:37:34] 150 Opening BINARY mode data connection for skin_global.php
[14:38:12] 41953 bytes transferred. (1,06 kB/s) (00:00:38)
[14:38:52] Timeout (40s).
[14:38:52] Active Help: http://www.smartftp.com/support/kb/index.php/74
[14:38:52] Client closed the connection.
[14:38:52] Resolving host name "anaxyd.*******.com"
[14:38:52] Connecting to **.**.***.** Port: 21
[14:38:53] Connected to anaxyd.*******.com.
[14:38:53] 220 ProFTPD 1.2.9 Server (ProFTPD) [hex12.******.com]
[14:38:53] USER ****
[14:38:54] 331 Password required for ******.
[14:38:54] PASS (hidden)
[14:38:54] 230 User ****** logged in.
[14:38:54] SYST
[14:38:54] 215 UNIX Type: L8
[14:38:54] Detected Server Type: UNIX
[14:38:54] FEAT
[14:38:55] 211-Features:
[14:38:55] 211-MDTM
[14:38:55] 211-REST STREAM
[14:38:55] 211-SIZE
[14:38:55] 211 End
[14:38:55] PWD
[14:38:56] 257 "/" is current directory.
[14:38:56] CWD /anaxyd.******.com/forums
[14:38:56] 250 CWD command successful.
[14:38:56] PWD
[14:38:57] 257 "/anaxyd.******.com/forums" is current directory.
[14:38:57] TYPE A
[14:38:57] 200 Type set to A
[14:38:57] PASV
[14:38:57] 227 Entering Passive Mode (****************).
[14:38:57] Opening data connection to **.**.***.** Port: 36190
[14:38:57] LIST -aL
[14:38:58] 150 Opening ASCII mode data connection for file list
[14:38:58] 583 bytes transferred. (1,58 kB/s) (359 ms)
[14:38:58] 226 Transfer complete.
[14:38:59] Transfer failed.
[14:39:49] NOOP
[14:39:49] 200 NOOP command successful
[14:40:40] NOOP
[14:40:40] 200 NOOP command successful
[14:41:31] NOOP
[14:41:32] 200 NOOP command successful
Er det ingen mulighet å få lastet opp alt sammenhengende uten "Transfer Error's"?
Hadde vært kjekt om jeg bare kunne sette den til å laste opp, gå og gjøre noe annet imens, og komme tilbake og se at alt er blitt lastet opp uten å passe på..
Hadde vært bra med svar! :)
Endret av AnaXyd
