"Unable to load authentication library, Exiting.."
Jeg får denne feilmeldingen når jeg skal spille mot botter på CS:Source:
Noen som vet hvordan dette kan fikses?
Endret av Sawron
Prøv dette:
Get the dedicated server via Steam, start it once and then take the steamclient.dll from
...Steam\Steamapps\<Username>\source dedicated server\bin
and place it in
...Steam\Steamapps\<Username>\counter-strike source\bin
If there is one already, rename it or just replace it with the one the dedicated server. If ther is none (as in my installation), just put in in there.
