Shadow Of the colossus hjelp
Nope. Du skal klatre opp på veggene på siden av "banen".
SPOILER :)
Klikk for å se/fjerne innholdet nedenfor
You are at an advantage because you can climb, and he can't. The way you'll want
to start is by first climbing on the fallen stone pillar behind you. Use it to
reach an elevated pathway behind you. Then use that to reach another pathway.
Use that path way to get to a pillar. Jump to the top of it and wait for him to
hit it. If it doesn't fall, shoot an arrow at the lion to get him to hit it
again. With the pillar over, you can jump to the walkway in front of you. Use
that and head to the right, jumping the gap, over a wall, to another walkway on
the other side, where you can access another pillar. Have him hit it until it
falls. Before it hits the ground, jump to the next pillar, and repeat the
process for each pillar. If you do happen to fall off, you can just jump from
the fallen pillar to the lowest ring of the next one. From the third, jump to a
platform, then to the next pillar. From the last pillar, jump to a walkway, then
to the climbable wall about halfway. Shimmy around to the left or the right,
jump up to the highest ledge, then shimmy to the back side get up on the
platform. From here, jump to the pillar and then he'll smash it into a wall,
shattering it.
Part 2. From where the pillar fell, run straight to the back wall and climb the
rock ladder. Head up the stairs and stand on the pillar. Locate him and shoot
him with an arrow to provoke him into hitting a stone support. He'll smash it
and the whole platform will fall on top of him, breaking his armor. Stand on a
pillar of boxes and he'll ram it, knocking him out. Now you can grab its back
and stab away at him until it dies.
Hvor, utenfor??
7495409[/snapback]
The way you'll want
Read please. Står jo der. Når du møter han, snur du deg 160 grader rundt og klatrer opp "the fallen stone pillar". Han slår klubben sin etter deg også kan du klatre opp. :)
Høyre eller venstere, spiller ingen rolle (tror jeg). Å hvis du ser på høyre eller venstere side helt bakerst kan du se en lang "steinplanke" som ligger der. Er litt lenge siden jeg har spilt spillet nå, men det er den som skal tippe.
Nei nei. Du skal få noe som allerede ligger på bakken til å "tippe". Som gjør at du blir løftet litt opp og kan gå bak stolpene. Skal se om jeg finner bilde.
Spoiler igjen
You need to get up to the walkway on the left of the area,
your character can't jump high enough to grab so he can pull himself to the
ledge. Stand just below the ledge, the giant will come towards you. When you
see it lift its foot to stomp, move to the side, it will lift the tile, creat-
ing a ramp for you to climb up so that you can get on the ledge.
Endret av Vorpal
Å steike, tok nr. jeg :). Her kommer ny:
It's big, REALLY big. First off, use your sword's light while you still can to
scope out its vital point, which is on the palm of the hand that is holding the
gigantic sword. While he is coming stomping towards you, the only thing you can
really do is run! You need to get up to the walkway on the left of the area,
ing a ramp for you to climb up so that you can get on the ledge. How nice of
it, though I suspect that it wasn't intentional... You have to climb up fast,
because when the giant removes its foot the tile will fall back into place.
Move over to one of the stones along the walkway, now just wait for the giant
to swing his sword. Once he does, it will knock down a stone, allowing you to
climb up to the next level.
Move to the end of the walkway, careful not to fall, and climb up the two sets
of stairs. Now that you are this high, use your sword to scan the giant's vital
point. There is a vital point on his head, now move across the top walkway and
go onto the bridge that connects the two. Now when you notice that the big
brute is about to swing its sword, move to the side. It will smash the bridge,
now you need to get onto it. Wait until it comes close, jump and grab onto its
head. Hang in there! The colossus will shake its head like crazy, if your grip
meter needs to be recharged, stand on its shoulders. Charge up your strength
and strike the colossus' vital point a few times until it disappears. Climb
down his right arm, the one that is holding the sword, and look for the blue,
glowing mark. Charge up your strength, strike it and the giant will drop its
sword. Now you need to get onto its palm; this is easy, just wait around it
on ground level while he is dangling his arms, it will eventually lower its
hand low enough to the ground for you to grab on. Just jump into his palm
and strike the symbol. If this doesn't work, the other way to do this is to
stand in front of the colossus and wait for it to slam the ground with its
fist. When it does, quickly move towards its fist and grab onto its palm.
Strike the vital point as many times as needed to kill the giant. One more
colossus to go!
Jeg har kommet meg opp på et sted etter man har vippet de greiene på siden. så er jeg bak noen stolper, men da sier den stemmen kom deg høyere opp. men det er ikke noen vei opp.
