Får feilmelding i DVD Shrink
Howiey
Prøver og ta en backup av en dvd-film som jeg har.
Men får en feilmelding når den skal begynne og brenne.
Ser ut til og være noe problem med Nero...
Noen som har peiling?
1A21-0009-8030-2451-2688-1302
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'K:\Programfiler\Nero\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 11:54:32
NT-SPTI used
Nero API version: 6.6.1.4
Using interface version: 6.3.1.4
Installed in: K:\Programfiler\Nero\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 1, 4d
Recorder:            <_NEC DVD_RW ND-3550A>    Version: 1.05 - HA 1 TA 1 - 6.6.1.4
Adapter driver:      <IDE>                    HA 1
Drive buffer  :      2048kB
Bus Type      :      default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral      : IC35L090AVV207-0                atapi Port 0 ID 0  DMA: On
DiskPeripheral      : WDC WD3000JB-00KFA0              atapi Port 0 ID 1  DMA: On
CdRomPeripheral      : SAMSUNG DVD-ROM SD-616E          atapi Port 1 ID 0  DMA: On
CdRomPeripheral      : _NEC DVD_RW ND-3550A            atapi Port 1 ID 1  DMA: On
=== CDRom-Device-Map ===
SAMSUNG DVD-ROM SD-616E    D:  CDRom0
_NEC DVD_RW ND-3550A      E:  CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE          : 0
Physical memory    : 1023MB (1048048kB)
Free physical memory: 503MB (515800kB)
Memory in use      : 50 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.12.2006
NeroAPI
17:28:04 #1 Phase 112 File APIProgress.cpp, Line 275
DVD-Video files reallocation started
17:28:04 #2 Phase 114 File APIProgress.cpp, Line 275
DVD-Video files reallocation completed (no file modified)
17:28:04 #3 Phase 111 File APIProgress.cpp, Line 275
DVD-Video files sorted
17:28:04 #4 NEROAPI 7 File Burncd.cpp, Line 3095
Error:\nCannot connect TRF.
17:28:04 #5 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
17:28:04 #6 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.05.2006 22:16:24
File 'Drivers\PXHELP20.SYS': Ver=3.00.41a, size=36560 bytes, created 27.09.2006 22:53:22 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Det kan være flere grunner til denne feilen:
- for lite minne --> øk virutuelt minne
- mangler nero-drivere --> reinstaller nero
- 16x dvd brukes når brenneren bare takler max 8x --> flash brenner eller kjøp 8x
- nero 6.6.1.4 har noe i mot dvd-shrink --> gå ned en versjon til 6.6.0.18
For mer info, sjekk denne topic...
7524979[/snapback]
takker stort!
men jeg har ikke 16x dvd plater, men 16x brenner...
skal sjekke ut linken...
thanx
