importering med PHPmyAdmin [LØST]
# phpMyAdmin MySQL-Dump
# version 2.2.3
# http://phpwizard.net/phpMyAdmin/
# http://phpmyadmin.sourceforge.net/ (download page)
# Host: localhost
# Generation Time: Jun 24, 2006 at 01:01 AM
# Server version: 3.23.47
# PHP Version: 4.1.1
# Database : `blogbox`
# Table structure for table `comments`
CREATE TABLE comments (
 id int(25) NOT NULL auto_increment,
 bruker tinytext NOT NULL,
 navn text NOT NULL,
 dato int(20) NOT NULL default '0',
 epost text NOT NULL,
 kommentar longtext NOT NULL,
 postid tinytext NOT NULL,
 PRIMARY KEY  (id)
) TYPE=MyISAM;
# Table structure for table `news`
CREATE TABLE news (
 tittel varchar(255) NOT NULL default '',
 melding longtext NOT NULL,
 userid int(20) NOT NULL default '0',
 reads int(20) NOT NULL default '0',
 PRIMARY KEY  (id)
) TYPE=MyISAM;
# Table structure for table `pmelding`
CREATE TABLE pmelding (
 sendid int(20) NOT NULL default '0',
 toid int(20) NOT NULL default '0',
 title text NOT NULL,
 message longtext NOT NULL,
 date int(20) NOT NULL default '0',
 haveread tinyint(2) NOT NULL default '0',
 PRIMARY KEY  (id)
) TYPE=MyISAM;
# Table structure for table `users`
CREATE TABLE users (
 First_name text NOT NULL,
 Last_name text NOT NULL,
 brukernavn text NOT NULL,
 passord text NOT NULL,
 signup_time int(20) NOT NULL default '0',
 last_loggedin int(20) NOT NULL default '0',
 activated tinyint(4) NOT NULL default '0',
 showemail tinyint(4) NOT NULL default '1',
 PRIMARY KEY  (id)
) TYPE=MyISAM;
Får denne feilmeldingen ved importering av mysql-database:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'reads int(20) NOT NULL default '0',
 PRIMARY KEY  (id)
) TYPE=MyISAM' at line 7
Noen SQL-proffer her som kan hjelpe en SQL-n00b som meg? Skjønner ikke hva som kan være feil, filen er eksportert med phpmyadmin, men til nå har jeg bare fått inn comments-tabellen
Endret av -XaHc-
Jeg tror "reads" er et reservert ord, for det funker hvis du f.eks. endrer navnet på denne attributten til "news_reads".
7422985[/snapback]
Det var riktig det.. Fikk et lignende problem før.. Databasen er lagd med phpmyadmin, kanskje den bruker omveier for å lage tabeller med reserverte ord
