xxm0rtyque Skrevet 6. juni 2006 Skrevet 6. juni 2006 Noen som vet hvordan jeg åpner denne? DAA-fil Svar så fot som mulig . Mvh Morten aKa Vivalamorten
wolf5 Skrevet 6. juni 2006 Skrevet 6. juni 2006 DAA = PowerISO Direct-Access-Archive (http://filext.com/detaillist.php?extdetail=DAA) PowerISO is a CD/DVD image file processing tool, which allows you to open, extract, create, edit, compress, encrypt, split and convert ISO files, and mount these files with internal virtual drive. It can process almost all CD-ROM image files including ISO and BIN. DAA is a format for an image file, which supports some advanced features, such as compression, password protection, and splitting to multiple volumes (similar to .RAR and other compression formats). Kan åpnes med program: http://www.poweriso.com/
