CSS map problem...
har laga map med hammer som jeg lagra... dagen etter fortsatte jeg med d og lagra endringan, men når jeg prøver å spille map'en så er ikke endringan der!?
hvis d hjelper så er d her hva som sto i console:
Game.dll loaded for "Counter-Strike: Source"
CSoundEmitterSystem: Registered 835 sounds
CResponseSystem: scripts/talker/response_rules.txt (15 rules, 76 criteria, and 16 responses)
maxplayers set to 32
Heap: 256.00 Mb
Parsed 359 text messages
execing config.cfg
cc_lang =
Sound Initialization
Set primary sound buffer format: yes
Using secondary sound buffer
2 channel(s)
16 bits/sample
44100 samples/sec
DirectSound initialized
Sound sampling rate: 44100
1 CPU, Frequency: 6.4 Ghz, Features: AuthenticAMD SSE SSE2 MMX 3DNow RDTSC CMOV FCMOV
execing valve.rc
material "vgui/servers/icon_secure_deny" not found
--- Missing Vgui material vgui/servers/icon_secure_deny
execing game.cfg
Network: IP 192.168.1.101, mode MP, dedicated No, ports 27015 SV / 27005 CL
Spawn Server martin1
Begin loading faces (loads materials)
End loading faces (loads materials)
else
execing skill1.cfg
Executing listen server config file
Summary: 203 resources total 13.24 Mb, 4.93 % of capacity
CInstancedSceneResourceManager: 0 .vcds total 0 bytes, 0.00 % of capacity
The Navigation Mesh was built using a different version of this map.
ERROR: Unconnected ladder #1 bottom at ( 0, -992, 0 )
ERROR: Unconnected ladder #2 bottom at ( 992, 0, 0 )
ERROR: Unconnected ladder #2 top at ( 992, 0, 1024 )
ERROR: Unconnected ladder #3 bottom at ( 0, 992, 0 )
ERROR: Unconnected ladder #4 bottom at ( -992, 0, 0 )
The nav mesh needs a full nav_analyze
Created class baseline: 5 classes, 870 bytes.
32 player server started
couldn't exec listenserver.cfg
Client Fjelltroll connected (127.0.0.1:27005).
Connected to 127.0.0.1:27015
Compressing fragments (25635 -> 12294 bytes)
Adding master server 207.173.177.11:27011
Adding master server 68.142.72.250:27011
Map: martin1
Players: 1 / 32
Build 2707
Server Number 1
Initializing renderer...
Level unlit, setting 'mat_fullbright 1'
Couldn't find customization file 'sound/player/jingle.wav'.
Compressing fragments (2612 -> 2289 bytes)
Error! CMapOverview::SetMap: couldn't load file resource/overviews/martin1.txt.
"materials/Effects/FilmScan256.vtf": can't be found on disk
"materials/Effects/Splotches256.vtf": can't be found on disk
scene_manager(.PAVCBaseEntity@@) thinking for 13.55 ms!
Compressing fragments (1460 -> 1028 bytes)
Signon traffic "CLIENT": incoming 16.288 Kb, outgoing 999 bytes
Game will not start until both teams have players.
Scoring will not start until both teams have players
jeg har også prøvd å lagre d på nytt men mange forskjellige navn uten resultat...
fikk ikke lagt ved map'en... trykka på "legg til dette vedlegget" også skjedde d ingenting...
håper noen kan hjelpe meg :thumbup:
Endret av Hellriser
