Hvordan spore en IP adresse?
Hvordan kan jeg spore en IP adresse?
Kan jeg finne ut hvor den personen sitter?
IP`en er 80.239.127.18 btw.
Vist noen kan finne det ut så hadde det og vært fint, men vil gjerne "lære" det selv og :)
Takker for svar :cool:
Hei !
Det finnes mange muligheter for å spore ip adresser. Ved å søke på f.eks "trace ip" i google så får du opp mange alternativer for å spore ip adresser
5501198[/snapback]
whois 80.239.127.18
[Querying whois.ripe.net]
[whois.ripe.net]
% This is the RIPE Whois query server #1.
% The objects are in RPSL format.
% Note: the default output of the RIPE Whois server
% is changed. Your tools may need to be adjusted. See
% http://www.ripe.net/db/news/abuse-proposal-20050331.html
% for more details.
% Rights restricted by copyright.
% See http://www.ripe.net/db/copyright.html
% Note: This output has been filtered.
% To receive output for a database update, use the "-B" flag.
% Information related to '80.239.127.16 - 80.239.127.19'
inetnum: 80.239.127.16 - 80.239.127.19
netname: NO-SONG-NOROFF-LINK
descr: NOROFF OSLO
country: NO
admin-c: TENO2-RIPE
tech-c: TENO2-RIPE
status: ASSIGNED PA
remarks: INFRA-AW
mnt-by: TELE1-NO-MNT
source: RIPE # Filtered
role: Tele1 Europe Norways role Object
address: TDC Song AS
address: Postboks 4600 Nydalen
address: NO-0405 Oslo
address: Norway
phone: +47 2150 2100
fax-no: +47 2150 2151
remarks: trouble: [email protected]
admin-c: ST62-RIPE
tech-c: POO9-RIPE
tech-c: SL1948-RIPE
tech-c: JKF3-RIPE
tech-c: FJ106-RIPE
tech-c: DVS10-RIPE
tech-c: TC1372-RIPE
tech-c: FL4732-RIPE
tech-c: ST62-RIPE
tech-c: EJ241-RIPE
tech-c: HKE4-RIPE
tech-c: RP3151-RIPE
nic-hdl: TENO2-RIPE
abuse-mailbox: [email protected]
% Information related to '80.239.0.0/17AS3246'
route: 80.239.0.0/17
descr: NO-SONG-NORWAY
origin: AS3246
mnt-lower: TELE1-NO-MNT
mnt-routes: TELE1-NO-MNT
