.Marcus Skrevet 6. februar 2006 Skrevet 6. februar 2006 15/16/10 slo stort sett alltid Seal Fate-rogues, dagger builds var uansett på topp på Vaelastrasz. 5560592[/snapback] Kan du fortelle meg denne 15/16/10 builden?
Slåmeg Skrevet 6. februar 2006 Skrevet 6. februar 2006 http://www.worldofwarcraft.com/info/classe...050000000000000
DeeTee Skrevet 6. februar 2006 Skrevet 6. februar 2006 16/25/10 skulle det være men, bomma litt på 2tallet Assassination Talents (16 points) # Malice - 5/5 points Increases your critical strike chance by 5%. # Ruthlessness - 3/3 points Gives your finishing moves a 60% chance to add a combo point to your target. # Improved Slice and Dice - 2/3 points Increases the duration of your Slice and Dice ability by 30%. # Lethality - 5/5 points Increases the critical strike damage bonus of your Sinister Strike, Gouge, Backstab, Ghostly Strike, and Hemorrhage abilities by 30%. # Relentless Strikes - 1/1 point Your finishing moves have a 20% chance per combo point to restore 25 energy. Combat Talents (25 points) # Improved Sinister Strike - 2/2 points Reduces the Energy cost of your Sinister Strike ability by 5 Energy. # Lightning Reflexes - 3/5 points Increases your Dodge chance by 3%. # Deflection - 2/5 points Increases your Parry chance by 2%. # Improved Backstab - 3/3 points Increases the critical strike chance of your Backstab ability by 30%. # Precision - 5/5 points Increases your chance to hit with melee weapons by 5%. # Dual Wield Specialization - 5/5 points Increases the damage done by your offhand weapon by 50%. # Dagger Specialization - 4/5 points Increases your chance to get a critical strike with Daggers by 4%. # Blade Flurry - 1/1 point Increases your attack speed by 20%. In addition, attacks strike an additional nearby opponent. Lasts 15 seconds. Subtlety Talents (10 points) # Camouflage - 5/5 points Increases your speed while stealthed by 15%. # Opportunity - 5/5 points Increases the damage dealt when striking from behind with your Backstab, Garrote, or Ambush abilities by 20%. I sub velger man egentlig det man trenger, men siden MoD ikke er så viktig PvE messig tar jeg heller litt speed i stealth. Dualweild spec, kombinert med +hit items og å alltid ha Slice'n'dice oppe - veksle par ganger med en evisc når man har flurry gående. Så går det nesten ikke ann å proppe ut mer damage med en daggerspec. Eneste skillen som scaler med gear er Slice'n'dice.
DeeTee Skrevet 6. februar 2006 Skrevet 6. februar 2006 Men sant som Gnurk sier, det er ikke speccen eller itemsa det kommer ann på alltid - men evnen til å kunne bruke det for å yte maksimalt samt være aktiv å gjøre sitt ytterste til enhver tid.
Gnurk Skrevet 6. februar 2006 Skrevet 6. februar 2006 15/16/10 slo stort sett alltid Seal Fate-rogues, dagger builds var uansett på topp på Vaelastrasz. 5560592[/snapback] Kan du fortelle meg denne 15/16/10 builden? 5560853[/snapback] Utifra foregående diskusjon ville jeg nå tro at det ikke var så vanskelig å tenke seg til at det var 15/26/10 jeg mente
wilzoo Skrevet 6. februar 2006 Skrevet 6. februar 2006 Det gear'et jeg postet tidligere var bare et gear som var absolutt maks attack power for å makse ambush/backstab. Selvfølgelig ville jeg ha byttet ut de blå itemsa med bloodfang i praksis men er veldig nær ved å skaffe alt dette gearet nå for tiden og har planer om å nå 1200AP unbuffet
