Feil mhv. til Limewire - fatal error i Java
Okay, her er det problemet:
Jeg har installert Limewire diverse ganger på en helt splitter ny PC, men programmet nekter å starte. Jeg har også prøvd å oppdatere Java til nyeste versjon - ingen forskjell.
Feilmeldingen jeg får opp er som følger:
LimeWire version 4.8.1
Java version 1.5.0_04 from Sun Microsystems Inc.
Windows XP v. 5.1 on x86
Free/total memory: 338792/5836800
FATAL ERROR!
java.lang.NullPointerException
at java.awt.Dimension.<init>(Unknown Source)
at javax.swing.plaf.basic.BasicProgressBarUI.getPreferredSize(Unknown Source)
at javax.swing.plaf.basic.BasicProgressBarUI.getMinimumSize(Unknown Source)
at javax.swing.JComponent.getMinimumSize(Unknown Source)
at javax.swing.BoxLayout.checkRequests(Unknown Source)
at javax.swing.BoxLayout.minimumLayoutSize(Unknown Source)
at java.awt.Container.minimumSize(Unknown Source)
at java.awt.Container.getMinimumSize(Unknown Source)
at javax.swing.BoxLayout.preferredLayoutSize(Unknown Source)
at java.awt.Container.preferredSize(Unknown Source)
at java.awt.Container.getPreferredSize(Unknown Source)
at javax.swing.JComponent.getPreferredSize(Unknown Source)
at java.awt.GridBagLayout.GetLayoutInfo(Unknown Source)
at java.awt.GridBagLayout.getLayoutInfo(Unknown Source)
at java.awt.GridBagLayout.ArrangeGrid(Unknown Source)
at java.awt.GridBagLayout.arrangeGrid(Unknown Source)
at java.awt.GridBagLayout.layoutContainer(Unknown Source)
at java.awt.Container.layout(Unknown Source)
at java.awt.Container.doLayout(Unknown Source)
at java.awt.Container.validateTree(Unknown Source)
at java.awt.Container.validate(Unknown Source)
at java.awt.Window.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at com.limegroup.gnutella.gui.GUIMediator$1.run(GUIMediator.java:321)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
-- listing session information --
Current thread: AWT-EventQueue-0
Active Threads: 16
-- listing threads --
async gui initializer: 1
Image Fetcher 3: 1
IconLoader: 1
Thread-3: 1
device search response: 1
Image Fetcher 2: 1
Java2D Disposer: 1
Thread-8: 1
TimerQueue: 1
main: 1
AWT-Shutdown: 1
AWT-Windows: 1
AWT-EventQueue-0: 1
Image Fetcher 1: 1
Timer-0: 1
Image Fetcher 0: 1
-- listing properties --
INSTALLED=true
FILTER_HASH_QUERIES=true
UNSET_FIREWALLED_FROM_CONNECTBACK=true
COUNTRY=
LAST_EXPIRE_TIME=1121343965125
CONNECTION_SPEED=350
CLIENT_ID=93683DA89CA842FF4CD43F6CE3B33900
Kan dere finne noe som tyder på en feil i Java, og kan dette i så fall rettes opp?
Hvis det er mer dere ønsker å vite om problemstillingen, bare spør.
På forhånd takk :)
Fredrik
