Rate my Preist PVP bulid
satt og lekte meg til en PVP bulid og vil ha litt kontruktiv krittik og noen meninger
Discipline Talents (19 points)
· Unbreakable Will - 5/5 points
Increases your chance to resist Stun, Fear, and Silence effects by 15%.
· Improved Power Word: Shield - 3/3 points
Reduces the duration of your Power Word: Shield's Weakened Soul effect by 15 seconds.
· Improved Power Word: Fortitude - 2/2 points
Increases the effect of your Power Word: Fortitude spell by 30%.
· Martyrdom - 2/2 points
Gives you a 100% chance to gain the Focused Casting effect that lasts for 6 seconds after being the victim of a critical strike. The Focused Casting effect prevents you from losing casting time when taking damage.
· Mental Agility - 5/5 points
Reduces the mana cost of your instant cast spells by 10%.
· Improved Mana Burn - 2/2 points
Reduces the casting time of your Mana Burn spell by ?.
Holy Talents (0 points)
· None
Shadow Talents (32 points)
· Spirit Tap - 5/5 points
Gives you a 100% chance to gain a 100% bonus to your Spirit after killing a target. For the duration, your Mana may regenerate at a 50% rate while casting. Lasts 15 seconds.
· Blackout - 5/5 points
Gives your Shadow damage spells a 10% chance to stun the target for 3 seconds.
· Improved Shadow Word: Pain - 2/2 points
Increases the duration of your Shadow Word: Pain spell by 6 seconds.
· Improved Psychic Scream - 2/2 points
Reduces the cooldown of your Psychic Scream ability by 4 seconds.
· Improved Mind Blast - 5/5 points
Reduces the cooldown of your Mind Blast spell by 2.5 seconds.
· Mind Flay - 1/1 point
Assault the target's mind with Shadow energy, causing 75 damage over 3 seconds and slowing the target to 50% of their movement speed.
· Silence - 1/1 point
Silence the target, preventing them from casting spells for 5 seconds.
· Shadow Weaving - 5/5 points
Your Shadow damage spells have a 100% chance to cause your target to be vulnerable to Shadow damage. This vulnerability increases the Shadow damage dealt to your target by 3% and lasts 15 seconds. Stacks up to 5 times.
· Darkness - 5/5 points
Increases your Shadow spell damage by 10%.
· Shadowform - 1/1 point
Assume a Shadowform, increasing your Shadow damage by 15% and reducing Physical damage done to you by 15%. However, you may only cast Shadow and Discipline spells while in this form.
NICHT vil ikke være holy specca enda og trenger ikke komments som smeller
like Good luck med og finne mc gruppe osv :roll: det ordner jeg selv :)
Endret av digitalglenn
Bytt ut spirit tap med shadow focus :) En fiende som ikke resister er gull verdt. Mana regen får du av vann fra mager uansett ;) Ellers så det ganske nice ut faktisk!
Endret av uberhunter
