trenger hjelp til mIRC!
Jeg er en stor bruker av mirc og cs og lagde en channel på mirc (#bergen.strikeforce), og så var dt en som skulle skaffe oss bnc, men det viste seg at han ikke gjorde...så til slutt ble jeg disconnected fra Quakenet og ble vist G-LINE....Noen som kan si hva jeg ska gjøre? Jeg kommer meg ikke inn. Jeg har prøvd å laste nytt script men det funket ikke:*(
Endret av WienerMan_TheReal
What is a g/k-line?
If you're trying to connect to QuakeNet and the server tells you that you have been K-lined or G-lined it means that you have been banned from QuakeNet, and the reason for that ban is *ALWAYS* sent out right after the server tells you that you are banned. Some scripts and bots (showdown, eggdrop) doesnt show this reason but just says that you're banned but there is always a reason given.
If you feel that you have been wrongfully banned or want the ban removed send an email to [email protected] and include the reason for the ban, your host/ip, when it happened and anything else you think we need to know in order to remove your ban.
G-lined
This quit message is displayed when a user is banned from the entire IRC network, for various reasons. QuakeNet *always* sends the G-Line reason, if you can't see it you should check your IRC client may be hiding it. The Rules FAQ provides a section explaining the reasons for disconnection or banning from the network. For G-line enquiries you may email [email protected].
Dette er tatt fra Quakenet sin hjemmeside. ( www.quakenet.org )
