Nero klarer ikke å brenne dvd, hva er galt?
Pyro
Jeg har akkurat kjøpt meg en ny dvd brenner en BENQ DW1620. Men når jeg går inn i nero vision express og velger den filen jeg vil ha på dvd'en så skal den forberede filen for brenning og så brenne etterpå. Men jeg får istedet opp en feil melding om at den ikke kan brenne fordi: Unable to obtain Volume Interface Fikk også lagra en logg om dette:
00:14:54] DVDEngine  INFORMATION
[00:14:54] DVDEngine  cause: 255 (no_volume)
[00:14:54] DVDEngine  source: _MediaAccess::_MediaAccess()
[00:14:54] DVDEngine  description: Unable to obtain Volume Interface
[00:14:54] DVDEngine  ----------------------------------------------------------------------------------------
[00:14:54] DVDEngine  DVDENGINE exception caught.
[00:14:54] DVDEngine  END: IDVDPVRSessionImpl - BeginDiscAccess
[00:14:54] DVDEngine  BEGIN: DVDSessionBase - GetDVDFormat
[00:14:54] DVDEngine  ...DVD format = 'DVDFMT_DVDPR' DVD+VR(DVD+R)
[00:14:54] DVDEngine  END: DVDSessionBase - GetDVDFormat
[00:14:54] DVDEngine  BEGIN: IDVDPVRSessionImpl - GetDiscState
[00:14:54] DVDEngine  ...state = 0
[00:14:54] DVDEngine  END: IDVDPVRSessionImpl - GetDiscState
[00:14:54] DVDUI      Disc access successfull
[00:14:54] DVDEngine  BEGIN: DVDSessionBase - GetSessionUID
[00:14:54] DVDEngine  END: DVDSessionBase - GetSessionUID
[00:14:54] DVDEngine  BEGIN: DVDSessionBase - GetDiscUID
[00:14:54] DVDEngine  ########################################################################################
[00:14:54] DVDEngine  ERROR
[00:14:54] DVDEngine  cause: 2 (internal_error)
[00:14:54] DVDEngine  source: DVDSessionBase
[00:14:54] DVDEngine  description: Disc access required.
[00:14:54] DVDEngine  END: DVDSessionBase - GetDiscUID
[00:14:54] DVDEngine  BEGIN: IDVDPVRSessionImpl - EndDiscAccess
[00:14:54] DVDEngine  ...flags = 0
[00:14:54] DVDEngine  END: IDVDPVRSessionImpl - EndDiscAccess
[00:14:54] DVDEngine  BEGIN: DVDSessionBase - RegisterCallback
[00:14:54] DVDEngine  ...Session callback unregistered...
[00:14:54] DVDEngine  END: DVDSessionBase - RegisterCallback
Noen som har noen forslag til hva jeg gjør galt? Bruker Win XP home edition og Insenso dvd+r plater.
Hva slags disk er det du skal brenne, skal du lage en dvd med Avi eller mpeg-filer?
Skal du brenne en Image-fil (f.eks ISO) er det vel greiest å bruke vanlig Nero. Dette gjør jeg akkurat nå iallefall....
Har ikke fått prøvd NeroVision enda fordi den klager på språk hele tiden. Driver å laster ned enda en oppdatering men det tar sin tid med 1.2k/sec fart....
Bruker du WinXP SP2? Isåfall må du vel laste ned noen oppdateringer
Høres litt snodig ut. Har du vanlig nero også? (ikke den vision saken). Mener da at den skulle fungere fint... det fungerer ikke uansett hva du brenner?
Nei, har prøvd forskjellige ting. Stopper alltid på 2%. Bruker Intenso DVD+R 1-8 x plater forresten
Du kan prøve å avinstallere Nero og installere det på nytt.
Hjelper ikke det kan du vel installere Win på nytt selv om det er litt arbeid, gjerne formater HD med det samme.
Å formatere er ikke aktuelt. Men jeg kan brenne vanlige plater, bare ikke dvd+r plater. Så da hjelper det vel ikke å installere på nytt.
