fsx v1.1 Skrevet 7. juli 2010 Skrevet 7. juli 2010 det kommer denne erroren "just cause was unable to start. Please make sure that you have installed the lastest drivers for you grapich cand and directX. in addition, please make sure that you graphic card supports the funcitions vertex shader 1.1 and pixel shader 1.1. For further information and troubleshooting, please refer to redame file." hva vil det si? har er system spes Intel® Graphics Media Accelerator Driver for Mobile Report Report Date: 07/07/2010 Report Time[hr:mm:ss]: 16:21:52 Driver Version: 6.14.10.4764 Operating System: Windows XP* Home Edition, Service Pack 3 (5.1.2600) Default Language: Norwegian (Bokmål) DirectX* Version: 9.0 Physical Memory: 503 MB Minimum Graphics Memory: 8 MB Maximum Graphics Memory: 128 MB Graphics Memory in Use: 10 MB Processor: x86 family 6 Model 13 Stepping 8 Processor Speed: 797 MHZ Vendor ID: 8086 Device ID: 2592 Device Revision: 03 * Accelerator Information * Accelerator in Use: Mobile Intel® 915GM/GMS,910GML Express Chipset Family Video BIOS: 1284 Current Graphics Mode: 1280 x 800 True Color (60 Hz) * Devices Connected to the Graphics Accelerator * Active Notebook Displays: 1 * Notebook * Monitor Name: Display Type: Digital Gamma Value: 2,20 DDC2 Protocol: Supported Maximum Image Size: Horizontal: Not Available Vertical: Not Available Monitor Supported Modes: 1280 x 800 (60 Hz) Display Power Management Support: Standby Mode: Not Supported Suspend Mode: Not Supported Active Off Mode: Not Supported * Other names and brands are the property of their respective owners.
GnuNix Skrevet 7. juli 2010 Skrevet 7. juli 2010 (endret) Først oppgradere Direct X: http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en Det kunne ha vært lurt å oppgradere din skjermkort driver: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+controllers&ProductProduct=Mobile+Intel%C2%AE+915GM%2fGMS%2c+910GML+Express+Chipset+Family Har du spilt Just Cause på denne bærbar før? *********** Har ser du mange andre som har Intel integrert video som har det samme problem som deg: http://forums.eidosgames.com/showthread.php?t=63184 Endret 7. juli 2010 av jackbrennan2008
fsx v1.1 Skrevet 7. juli 2010 Forfatter Skrevet 7. juli 2010 nei har ikke kjørt spillet før på denne pc!. Men nå prøver jeg og instalere optatering til grafick kortet men jeg har den nyeste av direct det står at jeg har en nyere versjon av direktx
