xector1 Skrevet 15. juni 2003 Skrevet 15. juni 2003 Når jeg starter warrior kings: battles går det helt fint de 2 første minuttene. Men så helt plutselig stopper spillet og returnerer til skrivebordet helt uten mening, altså at spillet slår seg helt av. Noen som kan hjelpe meg med å fikse det? :-?
Ronino Skrevet 15. juni 2003 Skrevet 15. juni 2003 Se her (bla deg ned til "KNOWN ISSUES"): http://www.warriorkingsbattles.com/support/index.asp
xector1 Skrevet 15. juni 2003 Forfatter Skrevet 15. juni 2003 Se her (bla deg ned til "KNOWN ISSUES"):http://www.warriorkingsbattles.com/support/index.asp Jeg tok av intro videoen, men likevel klikker det, jeg holder på å installere windows update for å se om det fikser noe.
Ronino Skrevet 19. juni 2003 Skrevet 19. juni 2003 Har du prøvd siste oppdatering for spillet? Siste oppdatering: http://www.warriorkingsbattles.com/downloads.asp Leste litt i tekstfilen til oppdateringen: We have indentified the "Drop to desktop" crash as being possibly related tosome 3rd party audio codecs. To further isolate these, we have included an output file called filtergraph.txt which will be created in the "saved" directory. If you experience a crash, it will be very helpful if you can include the contents of this file in your bug report. As things stand we believe that there may be conflicts caused by the following codecs: Morgan Stream Switcher TFM Audio Filter Intervideo Audio Decoder DivXG400 Our advice is to try uninstalling these codecs if you are experiencing an apparently random drop to desktop. However, until we have gathered more data, we cannot guarantee this as a fix.
