MediaMonkey vil ikke legge mappene som spillelister i iPod (iPhone 2g)
Gjest Slettet+19283741
Jeg skriver dette på engelsk i tilfelle jeg må poste det videre på mediamonkey forumet. Dere som svarer kan godt svare på norsk, dette gjør jeg kun for å spare tiden på å ev oversette senere til engelsk (copy/paste til engelsk forum).
Software: MediaMonkey v3.2.0.1294
Software: Windows 7 Ultimate x64
Hardware: iPhone 2 generation
My question is simple:
How can I make MediaMonkey separate the several folders into playlist in iPhone when using auto sync on folders in MediaMonkey? (Playlist don't have the issue.)
MediaMonkey won't put my music in the iPod app with separate playlist. I.e. I set the iPhone to automatically sync a folder called "New Hits" and "Old Hits". After the sync is done, I go to iPod on my iPhone where both folders (containing several music files) "New Hits" and "Old Hits" is placed under the same playlist; "on the go"
I took some print screens of the proses so you maybe get an understanding of what I actually did.
1. Clicking on the selected item
2. iPhone is selected as an available unit for sync
3. Translated into English from Norwegian in the red circle: <Folder>\<Filename>
4. However, if I right click on a playlist or a folder directly and chose "send to" -> "iPhone sync." it will automatically lay under the correct playlist on iPod app in iPhone.
Any help is most appreciated!
