Gaming pc maks 7k
Hei jeg lurte på om noen kunne konfigurere denne Komplett Gamer i02 pcen sånn at jeg kan bruke den i noen år (2-3) , men ligge på rundt om 7000kr?
Vis dere har noen spørsmål er det bare å spørre eller andre forslag :)
Mvh. Turbolax
Endret av turbolax
Strømkabel PC m/Jord 2m
Nero 8 OEM Vista kompatibel
CyberLink DVD Suite 7, 6Channel, OEM CD
Støtsikker PC-eske
Qpad|UC, Small Komplett Black, 4mm,
In-Win J649 ATX Midi Tower Sort
ASUS P5Q SE2, P45, Socket-775
Intel Core™ 2 Quad Q8200 2,33GHz,
Lite-On DVD+RW burner IHAS124-19
USB2 multikortleser 3.5" sort for
Corsair TX 650W PSU
Corsair Value S. PC5300 DDR2 4GB
Samsung SpinPoint F3 500GB
Gainward GeForce 9800GT 1GB PhysX CUDA
PC Uten OS, White Box PC
Garanti 3 år - Sende inn
5.650,49
Mvh. Turbolax
Vil ikke se bort i fra at denne vil passe til ditt behov for fremtiden
Cooler Master HAF 922 Midi Tower Sort
ASUS P5QPL-AM, G41, Socket-775
Intel Core™ 2 Quad Q8400 2,66GHz,
Corsair VX 550W PSU
Kingston ValueR. DDR2 PC6400 4GB KIT CL5
XFX Radeon HD 4870 512MB GDDR5
MS COA Label Windows Home Premium 7
Pris: 6999,-
Hva har du tenkt å spille forresten? Eller, hva driver du mest med.
Endret av ee100
ser dette brukbart ut?
Cooler Master Centurion 590 Midi Tower Vifter: 1x 120mm Front, 1x 120mm Bak, Blå LEDs, 2x USB, 1x FW, Audio, 17
ASUS P5Q SE2, P45, Socket-775 DDR2, ATX, GbLAN, ICH10, PCI-Ex(2.0)16
Intel Core™ 2 Quad Q8200 2,33GHz, Socket 775, 4MB, 1333MHz, Boxed w/Fan
Lite-On DVD+RW burner IHAS124-19 SuperAllWrite, 24x8x16DVD+RW, SATA, Black
USB2 multikortleser 3.5" sort for CF I/II,MMC,RS MMC,MMC Plus,SD,SDHC,miniSD,microSD,MS (Pro, Duo),SM,xD (bulk)
Corsair TX 650W PSU ATX 12V V2.2, 80 Plus, Standard. 2x 6+2-pin PCIe, 8x SATA, 120mm Vifte
Corsair Value S. PC5300 DDR2 4GB Kit w/two matched Value Select 2048MB
Samsung SpinPoint F3 500GB 7200RPM, SATA 3.0 Gbps, 3,5", 16MB
Gainward GeForce 9800GT 1GB PhysX CUDA PCI-Express 2.0, GDDR3, DVI, native-HDMI, HDCP, Graphics Plus, "Green
Logitech Deluxe 250 Keyboard NO USB Sort OEM
Logitech OEM S-120 2.0 høyttaler Sort
PC Uten OS, White Box PC Skal kun brukes i PC Produksjon
Garanti 3 år - Sende inn PC sendes av kunde til Komplett.no
det kommer på 6094,- men er villig å betale 7000 så det er bare å kom med forslag på denne Komplett Gamer i02 pcen;)
Mvh. Turbolax
Corsair VX 550W PSU
Pris: 6999,-
spiller WOW , CSS , CS 1.6 og kommer nok til å spille nyere fps spill som kommer :D
For å være helt ærlig med deg så satt jeg å konfigurerte selv for morro skyld. Vurderer selv en upgrade. Men hør på ee100 når det gjelder RAM, Skjermkort og CPU, for jeg hakke peiling. :p
Har du noe som helst fra før? som kabinett, mus, tastatur, strømforsyning osv.?
Mus,tastatur og skjerm , mangler bare pc'n :p
Her er et forslag..
348451
Komplett Gamer i02
Varenr.: 348451
Støtsikker PC-eske
Antec Nine Hundred Midi Tower Sort
Intel Core™ 2 Quad Q8300 2,5GHz
Sony NEC Optiarc DVD±RW burner AD-7240S
Corsair TX 650W PSU
Western Digital Caviar® GreenPower™ 1TB
XFX Radeon HD 4870 1GB GDDR5
Logitech X-540 Høyttaler 5.1,
MS DVD Win H.P/Pro/Ultimate 7 NO 64bit
MS MANUAL Win Home Premium 7 NO
MS ROYALTY Win Home Premium 7 Nordic
Lagerstatus: Ubekreftet dato 1 stk. 2009-11-19
