Martin HaTh Skrevet 23. februar 2009 Skrevet 23. februar 2009 Lastet ned denne GG moden til Counter-Strike source, fiksa den osv. og alt funker BORTSETT fra deathmatch. // GunGame v4 English Server Configuration // v1.06 // // These are all the server settings available to admins to setup the GunGame // This is the default config file. To use a language other than English, change the // language setting in the es_gungame4.txt file and use the config file for that language. // Any alteration of this file requires a server restart or a reload of the GunGame before the changes will take effect. // //******************************** // LOAD TYPE //*********** // // How are you loading the GunGame on your server? // If you run the GunGame 24/7 and load it in your autoexec.cfg, select 0. // If you run the GunGame 24/7 and load it in your server.cfg, select 1. (this method is NOT recommended) // If you load the GunGame on a per map basis using map config files, select 2. // 0 = autoexec.cfg // 1 = server.cfg // 2 = map.cfg // gg_loaded 0 //******************************** // WEAPON ORDER //************** // // Your choices are: // // Pistols: // glock usp // p228 deagle // fiveseven elite // // Shotguns: // m3 // xm1014 // // Sub Machine Guns: // tmp mac10 // mp5navy ump45 // p90 // // Rifles: // galil famas // ak47 scout // m4a1 sg550 // g3sg1 awp // sg552 aug // // Machine Gun: // m249 // // Other: // hegrenade // knife // // Pick which ones you want and put them in order with level 1 being first in the list then level 2, level 3, etc. // You can repeat weapons if you like. // Separate each weapon with a comma ',' NO SPACES!! // gg_weapon_order "glock,usp,p228,deagle,fiveseven,elite,m3,xm1014,tmp,mac10,mp5navy,ump45,p90,galil,fam s,ak47,scout,m4a1,sg552,aug,m249,hegrenade,knife" // // Randomize weapon order at each mapchange // 0= no, 1= yes gg_random_weapon_order 0 //******************************** // PLAYER PUNISHMENT //******************* // // Number of levels players will lose if they commit suicide // 0= disabled // gg_suicide_punish 2 // // Number of levels players lose if they kill a teammate // 0= disabled // gg_tk_punish 0 // // Number of levels players lose if they disconnect and reconnect on the same map // 0= disabled gg_retry_punish 2 //******************************** // HANDICAP //********** // // Enable or disable the handicap system. // 1= enabled, 0= disabled // gg_handicap 1 // // Handicap Update 0=off, 1=on // If this is enabled, it will update all players that are below the current handicap every 2 minutes. // If it is disabled, players are only updated when they join the server. // gg_handicap_update 0 //******************************** // MAP OBJECTIVES //**************** // // Enable or disable map objectives in the game. If disabled, objectives will be removed from play. // 1= enabled, 0= disabled // gg_map_obj 0 //******************************** // JOIN MESSAGE //************** // // Enable or disable the message displayed to players when they join the server. // 1= enabled, 0= disabled // gg_join_msg 1 //******************************** // WINNER DISPLAY OUTPUT //*********************** // // When someone wins the game, it will display the winner's info and the scores list // using the included PHP script if you have that setup on your web server. // 0= off, 1= simple(ggwin.php), 2= expanded(gg4win.php) // // Note: If you turn this option on, you must edit one of the provided PHP scripts // and add them to a webserver. Point the URL below to the location of the script. // Also, this is VERY EXPERIMENTAL and there are so many things that can cause it // not to work for you. If you can't get it to work, then we suggest to just turn it off. // gg_winner_display 0 // // URL to the PHP file (ggwin.php for simple, and gg4win.php for expanded) // Do not include http:// // You must use the standard HTTP port 80. This will not work in-game if you specify a different port. // gg_winner_url "www.yourwebsite.com/gg4win.php" //******************************** // LEVEL MANAGEMENT //****************** // // Number of kills required to levelup // gg_multikill 0 //******************************** // AFK MANAGER //************* // // This controls what happens to players when they are afk, 0=off // Set this to the number of deaths a player is afk before the manager takes action, zero turns this feature off // gg_afk_deaths 5 // // This controls what action is taken if the AFK manager is ON // 1=kick from server, 2=moved to spectator // gg_afk_action 2 //******************************** // WARMUP ROUND //************** // // Turns on the warmup timer at the beginning of a map. Set to 0 (zero) to disable this feature. // gg_warmup_timer 5 // // This forces only one weapon during warmup if it is set. Setting it to 0 (zero) turns this off. // If this is disabled (set to zero), players will get whatever you setup in your weapon list for level 1. // gg_warmup_weapon "hegrenade" //******************************** // MAP PRESETS //************* // // These are the recommended map presets to be used for the GunGame. These will override any settings in your server.cfg file. // alias gg_map_setup "mp_timelimit 45; mp_winlimit 0; mp_chattime 18; mp_fraglimit 100" //******************************** // VOTING //******** // // Enable/disable end-of-map voting controls for the GunGame. // 0= off, 1= use mapcycle.txt, 2= use maplist.txt, 3= use ggmaplist.txt, 4= use Mani Admin Plugin // // Note: Options 1-3 may not work on your server if you have Mani's Admin Plugin loaded. // If you use Mani, you should use option 4. Make sure you have Mani's voting options setup correctly. // http://www.mani-admin-plugin.com/mani_admi...ation/index.php // gg_voting 0 // // Number of maps to include in the end-of-map vote, minimum= 1 // gg_vote_options 4 //******************************** // SOUNDS //******** // // Sound files // Put the exact file name here preceded with "gungame/" Make sure there are no spaces in it. // Rename the file if you have to remove any spaces in the name. // Put your sounds in the cstrike/sound/gungame directory // To disable a particular sound, leave it empty between the quotes: "" gg_sound_levelup "gungame/smb3_powerup.wav" gg_sound_leveldown "gungame/smb3_powerdown.wav" gg_sound_levelsteal "gungame/smb3_1-up.wav" gg_sound_nade "gungame/nade_level.wav" gg_sound_knife "gungame/knife_level.wav" gg_sound_welcome "" gg_sound_winner "music/HL2_song15.mp3" gg_sound_handicap "gungame/gg_handicap.wav" // // The triple level sound must be exactly 10 seconds long to work correctly with the Gun Game code // gg_sound_triple "gungame/smb_star.mp3" // // RANDOM WINNER SONG // 0=off, 1=on // gg_rand_song 0 // This will override your gg_sound_winner setting above and play a random song from this list. // EACH FILE MUST BE LOCATED IN YOUR /cstrike/sound/gungame/ DIRECTORY!! // Put each song filename in this list seperated by commas, NO SPACES!!! // gg_songlist "bombtrack.mp3,wakeup.mp3,stand_alone.mp3,matrixwin1.mp3,clickboom.mp3,dontstay.mp3,nu b.mp3" //******************************** // DATABASE //********** // // Prune database // If a player is inactive for this many days, they are deleted from the database. // Set this to zero to disable deletion, although that is not recommended. // gg_prune_database 30 //************************************************************ // ADDONS //******** // // Turn Knife Pro level stealing on/off 0=off, 1=on // gg_knife_pro 0 // // Knife Pro Level Limiter // Set this to limit level stealing to players close to your own level // Example: If this is set to 3, you will not gain a level if you knife someone more than 3 levels below you. // 0= disabled // gg_knife_pro_limit 5 // // Turn Triple Level Bonus 0=off, 1=on // Turbo Mode automatically overrides the Triple Level Bonus to OFF // gg_triple_on 0 // // Turn Turbo Mode 0=off, 1=on // This gives you your next weapon immediately when you levelup // Knife Elite automatically disables Turbo Mode. // gg_turbo 1 // // Knife Elite mode 0=off, 1=on // After a player levels up, they only get a knife until the next round. // THIS WILL OVERRIDE TURBO MODE!! // gg_knife_elite 0 // // Earn Hegrenades 0=off, 1=on // When a player reaches grenade level, they can earn extra grenades by killing enemies with another weapon. // Players can only carry one hegrenade at a time. // gg_xtra_grenades 0 // // Unlimited Hegrenades 0=off, 1=on // When a player reaches grenade level, they are given another grenade when their thrown grenade detonates. // This will automatically disable the Earn Hegrenades addon. // gg_unl_grenades 1 // // Grenade Level Bonus Weapon 0=off, <weapon name>= on // If this is set, players on grenade level will receive this bonus weapon also. // Set this to zero to disable this function. // gg_nade_bonus "0" // // Noblock Addon 0=off, 1=on // gg_noblock_enable 0 // // Auto Friendly Fire 0=off // Automatically turn on friendly fire when a player reaches x levels below the max // Example: gg_auto_ff 2 // This will turn on friendly fire when the player reaches 2 levels below the max gg_auto_ff 0 // // Stats Log Output 0=off, 1=on // This will log game events for stats tracking. // gg_levelup, gg_leveldown, gg_levelsteal, and gg_win gg_stats_log 0 // // Deathmatch Mode 0=off, 1=on // This will automatically enable Turbo Mode, and disable Knife Elite. // Map objectives are disabled for Deathmatch. // gg_deathmatch 1 //---------------------// // DEATHMATCH OPTIONS: // //---------------------// // // Spawn Protection 0=off // Set this to the number of seconds to allow spawn protection. // gg_dm_spawn_protect o // // Spawn Protection Disable on weapon_fire 1=on, 0=off // Turn off spawn protection when a player fires their weapon. // NOTE: This will cause considerably more lag on your server. // gg_dm_remove_protect 0 // // Spawn Delay 0=off // This is a delay after a player dies before they will respawn. // Recommended value: 2 gg_dm_spawntime 1 /////////////////////////////////////////////////////////////////////////////////////////// echo " " echo [GunGame] Config file executed. echo " " es_xdoblock gungame4/cont_setup Det var .cfg filen, har satt på deathmatch der, og prøvde å skrive gg_deathmatch 1 i console. Uten hell. Kan noen hjelpe meg?
Jooakim Skrevet 23. februar 2009 Skrevet 23. februar 2009 Du kan jo gå inn i serverconsole/screen og skrive "gg_deathmatch" og se hva den er satt til - og om kommandoen eksisterer. Om kommandoen ikke eksisterer, må du sjekke at alle plugins/moduler/annet er lastet ordentlig. Om den kommer opp som "0" i serverconsole, kan du prøve å skrive gg_deathmatch 1 (i serverconsole)/rcon gg_deathmatch 1 (console). Du kan også sette gg_deathmatch "1" i server.cfg, og eventuelt i kommandolinjen - "+gg_deathmatch 1". Ellers vil jeg anbefale SourceMod! http://sipi.ws/Guider/FeilsQking/guide/i.php?guide=sm http://forums.alliedmods.net/showthread.php?p=725749 http://forums.alliedmods.net/showthread.php?p=714723
Martin HaTh Skrevet 23. februar 2009 Forfatter Skrevet 23. februar 2009 fant det ut, problemet var at steam IDen min ikke var satt til admin, så den prøvde stadig å respawne med og mine venner (+ en del botter), men etter jeg fiksa på det funka det som en drøm.
