Guide til å legge til din egen Couter Strike: Source Intro
Gjest Slettet+513
Gjest Slettet+513
Snotrus AKA NightEagle brings you Enlightning.
JaJa, tenkte jeg skulle poste dette på et Norsk forum siden det kansje kan være spennende for noen. Fohåpentlig trenger jeg ikke å oversette for noen :)
Fette er en ganske gammel guide jeg skrev for ett Engelsk forum.
------------------ INFO ----------------------------------
Ever wanted to have your own small or big intro video in CSS?
So how to ENABLE a intro video? and use your own Windows Media Video?
(eks: Something.WMV)
By Feedback from users i have ReWritten the entire Tutorial. 4/29/2008
---------------------------- TESTED--------------------------------
Note: This Tutorial was fully TESTED and working with Music videos and movie Trailers with the format .WMV
[TIP: If your video has wrong format... convert it to .wmv using a converter and it should work if done right]
--------------------------- IMPORTANT ---------------------------------------
STEP Zero: It is important to do what i tell you now to not mess up something.
CSS uses WMV teknology so do not try to play a DivX or other video formats.
-----------------------------WARNING --------------------------------------------------------------------
ONLY TESTED ON CSS
CONFIRMED WORKING 100.0%
GOOD FOR MODS, OR PEOPLE THAT WANT THEIR OWN INTRO.
--------------------- Let's Get Startet -------------------------------------------
STEP 1: Find the Cstrike folder and create a folder with the name "media" (If you don't already have it) then create a subfolder named "ui" (If you don't already have it)
STEP 2: Find any video you have with the format ".WMV" (Windows Media Video) and COPY & PASTE it into the ui folder.
STEP 3: Rename the video to "gamestartup" [iNFO: Do not add .wmv to the video name]
STEP 4: Open Notepad and write the text below:
"C:\Program files\Counter-Strike Source\cstrike\media\ui\gamestartup.wmv"
[info: Has to be your media\ui\gamestartup.wmv location and must include the " " ]
Press Enter twice and write:
Enable video="True"
STEP 5: Save the Notepad file to C:\Program files\Counter-Strike Source\cstrike\media\ui as a normal textfile
Rename the text file: StartupVids [Tip: You can use "Save" in Notepad then type: StartupVids and click save]
STEP:6 Start Cstrike and Enjoy the intro! [iNFO: SKIP VIDEO by Pressing ESC, but ESC might not work for everyone]
----------------------END--OF--TUTORIAL---------------------------------------
IF THE INTRO VIDEO NOW WORKS.... CONGRATULATIONS!!! :D
--------------COMMENTS--FROM--TUTORIAL-WRITER-------------------------------
NIGHTEAGLE: I love Games and you do too :)
My first Tutorial.. THIS Tutorial.
II accidently discovered how to use videos in CSS
Thank you for all the feedback the past year
Give this the rating you think it deserves, I THANK YOU ALL for Reading my Tutorials.
------CREDITS------------CREDITS------CREDITS------------CREDITS------CREDITS------------
Tutorial Writer: NightEagle AKA Snotrus
YouTube Tutorial Maker: None
Edit: Orginal tekst hentet fra FPSbanana http://www.fpsbanana.com/tuts/edit/3956
[HELP Wanted: I need a nice young Gamer to make a YouTube video of this Tutorial as proof that it works, Iwill post the link to the Video in this Tutorial.]
Rating:
User Rating 8.8
Detail 8.5
Usefulness 9.0
Readability 9.0
bScore 8.8/10
Fans: 8
Hvis du får ett problem så fikk jeg denne opplysningen fra en bruker.
*NOTE Your video can be named anything so long as its referenced in the "StartupVids.txt" file.
*NOTE: Make sure you run your game without any cvars like "developer 1" because it will not display any video or background map when you launch the game.
Vanskelighetsgrad: Viderekommen.
Dette er vel det som jeg skrev for ett år siden men skrev på nytt i år og er fremmdeles ikke ferdig med å gjøre den bedre.
Merk: Dette er kopiert og limt inn her, ikke skrevet helt på nytt på Norsk.
Må bare få baklage for engelsken min.
Ha en Riktig God Jul.
Endret av Slettet+513
