pfa87 Skrevet 15. april 2007 Skrevet 15. april 2007 Har et program som dmg fil, hvordan kjøres programmet? Tror ikke det er en type image siden det ikke gav resultat i daemon-tools.
bernini Skrevet 15. april 2007 Skrevet 15. april 2007 En mac med OSX er en start. Er som oftest der .dmg filer brukes. Vet ikke om det fungerer i Windows også.
ostov Skrevet 15. april 2007 Skrevet 15. april 2007 (endret) First copy all of your .dmg files to your hard drive. I copied mine to a folder within my PearPC (PPC) folder which I named MACOSX. Directory path = F:\PPC\MACOSX. I also renamed all of the files to make it easier to type them in the command prompt. I named them MAC1, MAC2, and MAC3. Be sure to include the file extension .dmg if you rename them. Copy the dmg2iso exe into the same folder as your newly copied .dmg files. Now open up a command prompt window. © Copyright 1985-2001 Microsoft Corp. Command prompt open C:\Documents and Settings\Your Name>F: I typed “F:” to change disks F:\>cd \PPC I now changed to directory PPC, my PearPC folder F:\PPC>cd /MACOSX then to MACOSX by typing "cd /MACOSX" F:\PPC\ MACOSX >dmg2iso MAC1.dmg MAC1.iso then I typed “dmg2iso MAC1.dmg MAC1.iso” dmg2iso v0.2c by vu1tur ([email protected]) reading property list...ok found 9 partitions decompressing: partition 0...ok partition 1...ok partition 2...ok partition 3...ok partition 4...ok partition 5...ok partition 6...ok partition 7...ok partition 8...ok conversion successful F:\PPC\ MACOSX > The application took a couple of minutes to finish, but successfully resulted in 3 cd image files. http://filext.com/info/showthread.php?t=160&page=2 Da vil fila blir konventert til en iso fil som du kan lett åpne. Du finner linken til det programmet på google akkurat som du finner svaret på spørsmålet ditt Endret 15. april 2007 av ostov
