Gjest Slettet-404071
Melding lagt til av Runar,
Det er sterkt ønskelig å legge ved kilder til nyhetsartikler, innlegg, bilder og lignende man poster, gjerne i form av en lenke direkte til der informasjonen stammer fra. Innlegg med spesielle påstander uten kilde kan bli slettet uten forvarsel.
READ 💬: Since the onset of its long-range air campaign in Ukraine, Russia has launched thousands of cruise missiles, suicide drones, and high-speed ballistic rockets against targets across the country. Among these weapons, ballistic missiles present the most dangerous threat because their hypersonic speeds and steep arrival angles leave air defense crews with only seconds to respond. However, sustaining this continuous bombardment has exposed a critical weakness in Moscow's defense industrial base: Russian factories simply cannot manufacture advanced ballistic missiles fast enough to match their firing rate on the battlefield.
To keep its long-range strike campaign operating at full intensity, the Kremlin has turned to North Korea for short-range ballistic missiles, primarily the solid-fueled KN-23 and KN-24 systems. Understanding why Moscow depends on these imported weapons reveals the severe pressures facing both Russian military stockpiles and Ukrainian air defenses.
The Production Gap in Russian Missile Factories 🔻
At the start of the conflict, Russia relied heavily on its homegrown Iskander-M ballistic missile system. The Iskander is highly accurate and capable of performing evasive maneuvers in flight, making it a primary tool for striking high-value targets. However, building an Iskander requires complex electronics, specialized rocket motors, and strict quality controls.
Even with Russian defense plants working in round-the-clock shifts, domestic production yields only a small number of Iskander missiles each month. During periods of heavy bombardment, Russian forces fire missiles much faster than assembly lines can replace them. Without an external source of supply, Russia would have been forced to drastically scale back its ballistic missile strikes to avoid completely draining its strategic reserves.
North Korea's High-Volume Alternative 🔻
North Korea offers an immediate solution to Moscow's supply shortage. For decades, Pyongyang built vast underground weapon facilities focused on mass-producing artillery shells and tactical ballistic missiles. North Korean systems like the KN-23 closely resemble the design of the Russian Iskander, carrying heavy warheads over hundreds of miles.
Because North Korean designs share similar operational concepts with Russian weapons, Russian launch crews require minimal training to deploy them. Sourcing hundreds of these missiles from Pyongyang provides Russia with a ready-made stockpile that can be plugged directly into existing combat operations.
Exhausting Ukrainian Air Defenses 🔻
Beyond filling factory shortfalls, firing North Korean missiles serves a clear tactical purpose: draining Ukrainian air defense stocks. Ballistic missiles travel on high-altitude arcs and descend at extreme velocities. Standard anti-aircraft guns and short-range surface-to-air missiles cannot touch them. Ukraine can only intercept these incoming threats using top-tier defensive systems like the U.S.-made Patriot.
Patriot interceptor missiles are extremely expensive and available in limited quantities worldwide. By launching waves of cheaper North Korean missiles alongside its own weapons, Russia forces Ukrainian defenders to expend precious interceptors. Every North Korean missile launched toward a Ukrainian city forces defenders to fire a multi-million-dollar interceptor, rapidly wearing down Ukraine's defensive shield.
A Mutually Beneficial Partnership 🔻
This missile trade provides major advantages to both regimes. For Russia, imported missiles sustain a relentless bombardment campaign that would otherwise stall due to domestic production bottlenecks. For North Korea, supplying weapons yields cash, oil, and assistance from Russian engineers to upgrade missile accuracy and guidance systems. Combat testing in Ukraine also gives Pyongyang real-world flight data to refine its weapon designs against modern defense systems.
Russia needs North Korean ballistic missiles because domestic factories cannot produce enough precision rockets to sustain a continuous long-range strike campaign. Importing missiles from Pyongyang allows Moscow to maintain relentless pressure on Ukrainian infrastructure while conserving its own high-end weapon stockpiles.
  • Innsiktsfullt 7
oddeh skrev (5 timer siden):
jøss
USA vedtar sanksjoner mot Russland og Iran
Senatet i USA har vedtatt nye sanksjoner mot Russland og Iran.
Det skriver NBC. Loven, oppkalt etter den nylig avdøde republikanske senatoren Lindsey Graham, skal ramme kjøpere av russisk olje og gas.
https://www.nrk.no/nyheter/1.17982719
Det kommer til å bli blokkert av Lille-Putin.
  • Liker 3
  • Innsiktsfullt 1
Ikke nødvendigvis. Husk at det er mellomvalg snart og taktikkeri rundt det å vise støtte til Ukraina. Som etter valget mest sannsynlig fordufter. I den forbindelse er det også svært populært innenlands at Trump viser respekt for Senator Lindsy Grahams siste ønsker. Dette er en Ukraina-positiv kampanje som kommer til å pågå helt til valgurnene stenger. Med Putins godkjennelse.
Endret av Simen1
  • Innsiktsfullt 4
iMarius skrev (13 timer siden):
Ukraina tom for missiler (VG)
Donald Trump er den største trusselen mot verdensfreden, og har vært det lenge. Hadde han hatt et snev av taktisk intelligens, ville man hatt rikelig med forsvar mot russiske missiler. Å sløse bort haugevis av missiler på Iran, er en mega-tabbe som gjør hele den vestlige verden ekstremt sårbare mot diktator-regimer i øst.
Hvorfor i all verden skal han nekte Ukraina å produsere patriot-missiler når det er åpenbart at USA ikke greier å produsere nok selv. Hvorfor lar de ikke Ukraina få tilgang til Starlink på angrep utenfor Ukraina. Det er jo helt hinsides all fornuft å la Putin få initiativet tilbake i krigen. Denne vinteren blir et helvete uten like, og den humanitære katastrofen som følger, blir enorm.
Det er helt sykt å tenke på at en søppelskalle av en president i USA skal få lov til å holde en hel verden som gissel med sine tåpelige avgjørelser.
Trumps tåpelige innfallsmetoder og mangelfulle IQ gavner ikke akkurat stabilitet og forutsigbarhet, men han håper vel på at Russland og Europa/Ukraina sliter ut hverandre mens han bruker opp all ammunisjonen i Iran.
Det vil ikke overraske meg mye om Kina nå benytter USAs tildels selvpåførte hengemyr og svake posisjon i både Iran og i Ukraina, til å gjøre noe med Taiwan
Sitat
Drone eksploderte over bulgarsk luftrom
Publisert klokken13:08 iBulgaria
Eksplosjonen skjedde i en solsikkeåker rundt én kilometer fra den transbalkanske gassrørledningen, opplyser statsministeren i Bulgaria, Rumen Radev.
Gassrørledningen går fra Ukraina til Tyrkia.
Dronen eksploderte rett ved grensen til Romania, nær den bulgarske grensebyen Kardam ved Svartehavet.
Ingen ble skadet i eksplosjonen, sier Radev i en videomelding fra Bulgarias regjering.
Kan dette vere ein russisk falsk flagg-operasjon av den typen som Litauen har åtvart mot? Det som manglar er at dronene viser seg å vere ukrainske.
Med den kommende mobiliseringa så er nok tapet på 8299 raskt fylt igjen. Det er et sisifos-arbeid. Krigen må løses på andre måter. Lavere enn sneglefart okkupasjon kommer heller ikke til å løse noen ting.
Jeg er ganske sikker på at løsningen er først økonomisk, deretter store interne omveldtninger og ny bølge av utbryterrepublikker.
  • Innsiktsfullt 2
torbjornen skrev (32 minutter siden):
Vet ikke om det er normalt, men vært veldig mye jagerfly-aktivitet fra Bulgaria rundt svartehavet de siste 2 dagene..
Ingen i dag, men mener det var på torsdag-fredag, evt onsdag-torsdag.
Endret av aklla
  • Innsiktsfullt 2
Det som er tragisk for Ukraina er at utrolig mange menn som kunne ha bidratt i krigen har forsvunnet. Google AI.
Det anslås at mellom 540 000 og 650 000 ukrainske menn i vernepliktig alder (18–60 år) befinner seg utenfor Ukrainas grenser etter å ha forlatt landet siden fullskalainvasjonen startet i 2022. I tillegg opplyser ukrainske militærmyndigheter at rundt 200 000 soldater har desertert, og at nærmere 2 millioner innkalte menn ikke har møtt opp til militærtjeneste internt i landet. [1, 2, 3]
Flukt og utreise av menn i vernepliktsalder
Selv om Ukraina innførte reiseforbud for menn mellom 18 og 60 år ved krigens start, har et stort antall likevel forlatt landet gjennom både lovlige unntak og ulovlige ruter: [1, 2, 3]
Utreise til EU: Eurostat-tall viser at over 1,1 millioner ukrainske menn har mottatt midlertidig beskyttelse i Europa. Dette tallet inkluderer imidlertid også eldre menn og gutter under 18 år. [1]
Undersøkelser av vernepliktige: Datasaneringer utført av uavhengige medier (som NGL.media) viser at minst 540 000 menn i ren mobiliseringsalder har reist ut og ikke returnert. Av disse anslås rundt 70 000 å ha krysset grensen ulovlig. [1, 2]
Regelendringer for unge menn: Befolkningstallet i utlandet økte ytterligere etter at ukrainske myndigheter i en periode tillot unge menn mellom 18 og 22/23 år å reise ut for studier og for å bevare bånd til utlandet. Dette førte til en stor utvandringsbølge høsten 2025. [1, 2, 3, 4]
Stanset på grensen: Ukrainske grensevakter rapporterer at de har stanset nærmere 50 000 menn som har forsøkt å rømme landet ulovlig. [1]
Situasjonen innad i Ukraina
Det er ikke bare utvandring som skaper mannskapsmangel for det ukrainske forsvaret:
Interne unndragelser: Det ukrainske militæret anslår at rundt 2 millioner menn aktivt unngår vernepliktskontorene ved å holde seg skjulte, oppgi falske adresser eller bruke korrupte medisinske fritak. [1, 2]
Desertering: Rundt 200 000 registrerte soldater har forlatt sine militære avdelinger uten tillatelse (AWOL/desertering) i løpet av krigsårene. [1, 2]
  • Innsiktsfullt 6
